Author Topic: Dug my car out after big snowstorm. Some jerk takes my street spot.  (Read 5163 times)
Offline vivalarevolución
[rant]
Anybody in the northern climes knows what I am talking about.  But here is the real kicker.  The nimrods that took my spot are the same idiots that spent two hours the other night burning rubber at high RPMs because they are too lazy to dig out the proper amount of snow and understand the principle of gently rocking the car back and forth.  I just knew I would see their vehicle parked in my spot when I got home.
Meanwhile, I had to force my car into some spot that will surely get me stuck in the morning.  I probably will spend the evening digging out some more spots.
I want to leave a note on their car and invite them over for a chat.
[/rant]
Offline esoomenona
  • Gnillort?
Re: Dug my car out after big snowstorm. Some jerk takes my street spot.
« Reply #1 on: Wed, 08 January 2014, 16:59:11 »
I heard something similar where a lady got shot for taking someone's dug out spot.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Wed, 08 January 2014, 17:47:00 »
Smash windshield and fill inside with snow then add some buckets of water to that  :thumb:
If you're not quite that mean spirited, just pouring some buckets of water over the outside every few hours to build up a nice ice shell is also good.
« Last Edit: Wed, 08 January 2014, 17:49:33 by IvanIvanovich »
Offline regack
« Reply #3 on: Wed, 08 January 2014, 17:52:08 »
...just pouring some buckets of water over the outside every few hours to build up a nice ice shell is also good.
too bad nobody uses keys to open car doors anymore...
« Reply #4 on: Wed, 08 January 2014, 18:07:24 »
They will still need to remove 1cm of ice to be able to see out while driving :))
Offline PointyFox
« Reply #5 on: Wed, 08 January 2014, 18:36:55 »
Also to open the door.
Offline JPG
  • Model F is my new passion!
« Reply #6 on: Wed, 08 January 2014, 18:40:46 »
Put that water where you fill the gas. It won't open when he does not expect it and won't know it's you unless he goes to the gas station directly!
« Reply #7 on: Wed, 08 January 2014, 18:41:36 »
I would be a little more subtle.
« Reply #8 on: Wed, 08 January 2014, 18:59:09 »
Pee on their handles
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #9 on: Wed, 08 January 2014, 19:21:02 »
If it is below freezing then you should take a bucket of water and dump it on his windshield every 20 minutes for the next 4 hours.  In the morning it will take him as long to remove the ice from his windshield as it took you to shovel the spot.  :)
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #10 on: Wed, 08 January 2014, 21:44:35 »
Surprised nobody suggested the idea of shoving down something small and solid through the muffler then filling the muffler with water. An age old trick when done properly can work great. Then there is always thermite based on home-made receipes when placed on engine bonnet near the engine block is enough to make anyone cry when they notice a hole that went through their bonnet and engine. It virtually makes the car useless.
On the lesser side of evil things, it really depends on where you park your car I suppose. If it is on your property, you should have some rights to put up a sign that says it is reserved, etc. On public roads, this is where the whole thing gets tricky.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #11 on: Thu, 09 January 2014, 00:08:47 »
Slash his tires
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #12 on: Thu, 09 January 2014, 00:22:48 »
Get some porcelain from a spark plug and break his windows.
It'll be a fun drive in the cold :)
Offline Oobly
« Reply #13 on: Thu, 09 January 2014, 01:13:55 »
Wow, you guys are mean. I'd go with the OP's "note and chat" rather than destroying property or layering their car in ice.
Not a nice thing to happen, but it's not uncommon. Reminds me of this:
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #14 on: Thu, 09 January 2014, 02:11:28 »
If you actually think that a "note and chat" is what it would be?  Because there is so much snow you could 'theoretically' shoot someone in a blizzard and then shove their bodies into the boot of their car.  You wait till the snow melts and then drive their car out to a dumping ground far away from your place.
When there, simply light the car up and all possible dna evidence will burn with the heat..... simple way to eliminate any problematic neighbour(s)  :thumb: .
« Reply #15 on: Thu, 09 January 2014, 03:55:43 »
As long as there are no CCTVs recording you anywhere near the car.
Offline Elrick
  • Hype Master
« Reply #16 on: Thu, 09 January 2014, 04:04:52 »
Don't worry when I plan to do something personally, everything has been expected and arranged to perfection  :thumb: .  Nothing better than a major national weather event that helps to facilitate a serious scheme.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #17 on: Thu, 09 January 2014, 04:17:52 »
LOL  :)) "Hey babe! I'm over here, come uncover me first before driving me off!". Next time maybe a wise(r) choice would be to invest in some car cover that probably wouldn't be as troublesome to deal with.
« Reply #18 on: Thu, 09 January 2014, 09:35:19 »
Great news!  I got my car out of the spot this morning without a problem.  So I'm not nearly as mad.
But my neighbors are still idiots, so I can't wait to see what they have up their sleeve next.
Offline berserkfan
« Reply #19 on: Thu, 09 January 2014, 10:31:50 »
If your neighbors are idiots I would advise you not to do anything. Don't get idiots worked up; bad things can happen. Idiots will do even more idiotic things in revenge (such as using thermite on your car, shooting you, etc.).
« Reply #20 on: Thu, 09 January 2014, 13:29:07 »
Yea, I'm not going to do anything.  I'm relatively harmless.   It's a waste of my time to think of ways to make life harder for other people.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #21 on: Thu, 09 January 2014, 14:58:31 »
how much snow do you guys have over there...........?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Novus
  • Mondai nothing~
« Reply #22 on: Thu, 09 January 2014, 15:13:37 »
I was going to say the exact same thing about the "note and chat" hahahaha.
We have too many cop shows though, local police might catch on to this nefarious plot because of some synthetic polyester strand left behind at the crime scene. DUN DUN DUN DUN DUN. OR they might have a mentalist... *queue theme song*
« Reply #23 on: Thu, 09 January 2014, 15:34:39 »
What? When you commit crimes you don't do it in a clean suit with reflective face shield to avoid leaving trace evidence and hide identity, wearing a magneto helmet to keep out the mind readers?
Offline Novus
  • Mondai nothing~
« Reply #24 on: Thu, 09 January 2014, 16:00:39 »
Nope, I only commit crimes of passion  :))
Premeditated crimes require too much planning and after all that planning the passion has worn off already.
« Reply #25 on: Thu, 09 January 2014, 16:13:44 »
Not much.  A foot.   But a foot in this town shuts everything down for a couple days.  The city does not have the equipment to handle that much snow.
Offline Elrick
  • Hype Master
« Reply #26 on: Thu, 09 January 2014, 17:11:52 »
That is why when there is a vicious blizzard with -40 no one will question anyone about wearing gear that resembles thick, heavy coats, or face shields, especially at night.  Plus very few people ever venture out in the dead of night, hence even less eye witnesses.  Trust me the police are given too much credit (due to fantasy shows on TV) because most of their cases are solved through witness statements and CCTV.  Eliminate those obstacles (including no dna/fingerprints) and they have nothing.
All you will see from the police is a desperate plea on TV asking for anyone to dob in their relatives and/or friends for a chance of receiving a reward.  That is when you know the police have absolutely nothing to go on.
You guys have it made in the US now, can you imagine what can be seriously done due to this type of amazing weather?  Here in Australia it's sweltering hot and every person and his dog is out on their front porch watching everything and everyone even at night.... much too risky in a built up area, ........far better in the bush.
« Last Edit: Thu, 09 January 2014, 17:14:27 by Elrick »
Offline BucklingSpring
« Reply #27 on: Thu, 09 January 2014, 21:16:36 »
[rant]Anybody in the northern climes knows what I am talking about.[/rant]
4 years ago I was really fed up with this crap. I now drive a 4Runner in winter. No need for a shovel anymore.
And since my street is mainly small cars. They can't access my parking "hole" unless they shovel a little. Which ain't going to happen.
Boards I own, click ->
Offline berserkfan
« Reply #28 on: Sun, 19 January 2014, 11:37:44 »
you must live in some rural or really snowy area? can't imagine that in a city where they pour salt everywhere. I really hated the salt; it makes your stuff filthy and damages it.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #29 on: Tue, 21 January 2014, 14:13:06 »
Wow, you're all evil. I like it.
You can go get a car battery and open and 'accidently' spill some battery acid on his or her car.
Sugar in gas tank, potato in muffler, cloth soaked in water that would be shoved into muffler. It will freeze and expand.
Slash tires, key his car car. Grab snow and dump it on his car so that he can't see the car.
