Author Topic: Help me find my Cherry brown keyboard?  (Read 2119 times)
Offline robertsig
« on: Thu, 09 January 2014, 08:49:28 »
I need some selection help!  I'm looking for a keyboard with these specifications, in order of preference.  Not sure if all can be hit.
TKL design.  Separate arrow keys, so a 86 or 87 key
Cherry Brown switches
PBT caps
USB and PS/2 compatibility (or at least PS/2 passthru capability)
White or white/gray
Factory installed red o-rings under caps
Basically the closest thing to available to the white Realforce 87U, but in a mechanical switch design.
Does such an animal exist?  I'm guessing the "white" part is the hardest.  All keyboards seem black these days.
Re: Help me find my Cherry brown keyboard?
« Reply #1 on: Thu, 09 January 2014, 08:51:02 »
Leopold FC700R from Hendyzone in the Classifieds fits everything except for the PS/2 requirement and pre-installed o-rings. Just FYI, I think only the G710+ from Logitech has pre-installed o-rings.
Offline robertsig
« Reply #2 on: Thu, 09 January 2014, 09:08:02 »
That board looks perfect!  Thanks.
Now if somebody just made a 50g uniform board without a click, I'd be in heaven.
« Reply #3 on: Thu, 09 January 2014, 09:10:57 »
Could always buy a MX Red/Black board then swap the springs to something close to 50g
Offline robertsig
« Reply #4 on: Thu, 09 January 2014, 09:22:29 »
That sounds perfect.  I need to read up on that. Is there a perfect 50g spring I can use?
Offline Oobly
« Reply #5 on: Thu, 09 January 2014, 14:21:00 »
Originative 67g springs may do the job. They are between MX light and MX heavy, but closer to the light springs. Imagine a line above the 62g one, with a similar slope:
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Oobly
« Reply #6 on: Thu, 09 January 2014, 14:23:46 »
On the other hand, you may also like stock or Ergo Clears. Tactile like browns, but a bigger bump and stronger spring.
Offline robertsig
« Reply #7 on: Thu, 09 January 2014, 16:11:42 »
Don't need a bigger bump, just a stronger spring.  I'd prefer linear (for games) but don't mind the small bump of the browns.
« Reply #8 on: Fri, 07 February 2014, 12:16:11 »
Nothing is "perfect". There will always be a tolerance band in parts. I believe originativeco.com is carrying 45g and 55g springs. Think sprit had 50g springs?
