Author Topic: Keycap Pullers - Your favourites and preferences  (Read 8124 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
« on: Sat, 11 January 2014, 02:14:18 »
So I wanted to know what everybody's favourite keycap pullers are.
The only ones I've used so far have been the WASD puller (wire) and one I got with my KC 84 (plastic ring pull). I have to say the plastic one (which I have recently lost, brilliant) is my favourite just because it is so easy to pull off multiple keycaps pretty quickly. The wire one is a pain because, on the keys I have used it on, it is too small for the cap which then comes off at an angle.
I know there actually aren't very many variations around, but which ones do you guys prefer using?
Offline Zeal
    • Zeal Generation Inc.
Re: Keycap Pullers - Your favourites and preferences
« Reply #1 on: Sat, 11 January 2014, 02:23:20 »
Wire keycap puller. It doesn't bruise the sides of my keys and I can remove longer unit keys.
I also think you're using the wire puller incorrectly. You're supposed to place the wires at a 45 degree angle so it latches onto the keycap corners, not along the whole keycap.
Like this:
Photo from BlueBar, http://geekhack.org/index.php?topic=46376.0
Offline fourzeropooh
« Reply #2 on: Sat, 11 January 2014, 02:43:13 »
I like the cherry wire puller
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Sat, 11 January 2014, 02:46:47 »
MKC stainless steel one I got from a friend.
« Reply #4 on: Sat, 11 January 2014, 02:59:04 »
Offline katushkin
  • Just the guy
« Reply #5 on: Sat, 11 January 2014, 03:23:00 »
Like this:
Ohhhhhhhhhhhhhh. That makes a lot more sense now! Oops.
Also, I think the plastic ring pull one is easier to pull long ones out. Although I would love to see someone make a puller to get an ISO return key out without touching any others.
« Reply #6 on: Sat, 11 January 2014, 03:50:56 »
Like this:
If you have one puller, ring is good for spacebars and the like. But what I do is for the spacebar, I take two paperclips, bend into a rectangle, and use those. Much better.
Ring scratches the caps, its really obvious in painted caps. Wire is smooth, and when you get used to it, its faster. Down, twist, up, knock out. Sometimes you don't even need to knock out until you have 2 or 3 on there.
With rings, its push down, click, up(sometimes doesn't stick correctly) then pop out, and repeat.
Offline Zeal
« Reply #7 on: Sat, 11 January 2014, 04:07:58 »
I dunno about you guys, but the ring pullers I've received were only able to remove keycaps when used horizontally, not vertically. So it wasn't able to pull out spacebars/shifts without having one end lose grip.
« Reply #8 on: Sat, 11 January 2014, 04:38:53 »
For the space bar, I remove both Alt keys and then use my fingers to gently lever it up, slightly rocking it back and forth.
Offline Zeal
« Reply #9 on: Sat, 11 January 2014, 05:06:46 »
Yep, that's what I do. Wire keycap puller handles everything else with easy :thumb:
Currently using the MKC Stainless Steel one at home and the free ducky one at work
Offline terran5992
  • One With The Cup Rubber
« Reply #10 on: Sat, 11 January 2014, 05:39:56 »
The MKC one is the best i ever used.
« Reply #11 on: Sat, 11 January 2014, 06:51:46 »
Offline katushkin
  • Just the guy
« Reply #12 on: Sat, 11 January 2014, 07:03:36 »
Some previous threads you can look through to get some ideas also
http://geekhack.org/index.php?topic=39943.0
http://geekhack.org/index.php?topic=46003.0
My personal favorite is this one
http://geekhack.org/index.php?topic=45795.msg967098#msg967098
Hah, so ghetto!
The MKC one looks awesome. Just another great GH thing I've missed out on :(
« Reply #13 on: Sat, 11 January 2014, 07:12:23 »
Hah, so ghetto!
You can get the MKC from geekhack user feng on ebay
http://www.ebay.com/itm/MKC-Stainless-Steel-Keycap-Puller-/330944917204
Offline katushkin
  • Just the guy
« Reply #14 on: Sat, 11 January 2014, 07:18:58 »
Ooo! Thank you! My wallet is screaming right not.
Offline ibell7945
« Reply #15 on: Sat, 11 January 2014, 20:20:09 »
I just use the Medium Blade flathead screwdriver on my Leatherman. Then again, I have been at this very long . . . is there a specially designed keycap puller for BS boards?
IBM 122 Key Model M
« Reply #16 on: Sat, 11 January 2014, 20:23:41 »
I have one that was supposed to be for IBM BS caps. It's weird looking.
« Reply #17 on: Sat, 11 January 2014, 20:28:08 »
I use a regular cherry puller
Offline Dubsgalore
« Reply #18 on: Sat, 11 January 2014, 20:32:38 »
use a techkeys one, want a wooden nubbs one, or an original cherry one
Offline ideus
  • Björkö.
« Reply #19 on: Sat, 11 January 2014, 20:33:25 »
A stainless steel butter knife.  :) . Not for tight-fitted keys though. For those a wire puller is always better.
« Reply #20 on: Sat, 11 January 2014, 21:25:38 »
Leopold version is my favorite.
- Oliver Willis 2026-08-01
Offline vivalarevolución
« Reply #21 on: Sat, 11 January 2014, 21:31:08 »
The techkeys orange wire one.  Because it's orange and easy to find if I misplace it.
« Reply #22 on: Sat, 11 January 2014, 21:33:45 »
Nubbs makes some good pullers.
Offline ideus
  • Björkö.
« Reply #23 on: Sat, 11 January 2014, 21:45:42 »
Leopold puller is a very nice one. I got one free included with the Fc660C. It is very nice.
Offline Dubsgalore
« Reply #24 on: Sat, 11 January 2014, 21:47:21 »
I want one for looks :p
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #25 on: Sat, 11 January 2014, 22:38:06 »
Yeesh, that is just asking for trouble!
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #26 on: Sat, 11 January 2014, 23:46:02 »
I just bought one from Nubbinator. Good craftsmanship, works great, looks great.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #27 on: Sun, 12 January 2014, 00:06:33 »
Like this:
whats the difference?
"Obviously, windows are central to Windows. But what is a window?"
Offline terran5992
« Reply #28 on: Sun, 12 January 2014, 00:07:15 »
Like this:
You might pull out the switch top
« Reply #29 on: Sun, 12 January 2014, 00:25:27 »
Like this:
1. In the first pic, you're pulling the cap only, not the switch with the cap attached.
2. This prevents you from pulling up the entire switch out of the PCB
3. NOTE: Only is affected when using PCB mounted switches, you won't pull up a switch using plate mounted ones.
Offline RESPRiT
  • HHKB = ❤
« Reply #30 on: Sun, 12 January 2014, 00:28:29 »
Leopold puller is really nice, before then I had the cheap plastic ring one, but I just used paper clips instead.
    • Force Project X
« Reply #31 on: Sun, 12 January 2014, 00:50:17 »
oh alright that makes sense . thanks guys
« Reply #32 on: Sun, 12 January 2014, 03:08:16 »
Can't blame ya.  They do look great.  :)
