Author Topic: Post Your 40% Keyboard  (Read 793185 times)
Offline Happylomo
Re: Post Your 40% Keyboard
« Reply #550 on: Mon, 19 December 2016, 04:57:30 »
long time lurker, first time poster. my planck I got through the first massdrop buy. got the planck borealis key set and cherry g81-3000 keys and 1up key for the led control.
Thats a really beautiful planck!! Damnn, i want a planck too now! How's that ortholinear setup working for u?
Offline menuhin
« Reply #551 on: Mon, 19 December 2016, 06:25:47 »
Have been thinking about the Planck add-on of the Borealis key set also.
Ideally of course is to also have the base set but then only the alpha keys will be used with a spending of another $90... So I'm still thinking.
Thanks for sharing.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline need
« Reply #552 on: Mon, 19 December 2016, 07:08:00 »
Nice board! How does it feel as compared to a normally staggered keyboard?
It's better as its symmetrical , but still feel cramped.
Offline menuhin
« Reply #553 on: Mon, 19 December 2016, 07:44:49 »
I don't have a Planck yet, but planning to have at least 1 (or even 2 one for Alps, one for MX).
How can one feels cramped on a Planck? Because it's homing keys are separated by the same distance as in a normal full-size keyboard.
Or is it the mods are 1u small or that is a bit psychological / perceptual effect?
« Last Edit: Mon, 19 December 2016, 09:19:28 by menuhin »
IBM M13 black
HHKB Pro 2 HasuBT
Offline PollandAkuma
« Reply #554 on: Mon, 19 December 2016, 11:10:34 »
Thanks for sharing.
Wanna get a Dasher/Dancer modifier set together? Maybe I can even proxy it to you :p
Offline menuhin
« Reply #555 on: Mon, 19 December 2016, 12:16:44 »
... Wanna get a Dasher/Dancer modifier set together? Maybe I can even proxy it to you :p
I stared at the Dasher & Dancer set massdrop for quite a while mesmerized by its simplistic beauty and its blue color also matches the blue theme of the 40% that I want to build...
But I came to my senses quite quickly: Dasher & Dancer is going to be here at the earliest Q3 2017, and I'm already plotting to get another SA set: DT Round 7 for a 'gigantic' ortholinear board.
On the other hand, Borealis is real - it will be shipped within a month and it's blue also and even GiD. :D
IBM M13 black
HHKB Pro 2 HasuBT
Offline adamsir2
« Reply #556 on: Mon, 19 December 2016, 22:20:15 »
My main keyboard is a poker 2 and when I switched to the Planck it had a small learning curve. You get used to reaching for certain keys which when using the Planck is the wrong key. After a full day of use though you get the hang of it. I have big hands so it feels a bit cramped when I switch back to it from the poker but I forget about it after a few minutes. Thinking about another Planck but this time building it myself and maybe my browns.
I was looking at the dasher/dancer keys but decided I'd rather finish getting the few parts needed to finish an ergodox build.
For the base set of the borealis keys, I thought about it but $90 for the alpha keys isn't worth it just yet imo. I'd really like to get a carbon set eventually for it.
Offline adamsir2
« Reply #557 on: Mon, 19 December 2016, 22:21:50 »
Thanks for sharing.
$22+shipping isn't a bad price. Plus the cherry set was $10 so I couldn't pass them up. Haha
« Reply #558 on: Wed, 21 December 2016, 03:11:43 »
DT Round 7?! brb dt-ing
Offline Tactile
« Reply #559 on: Sat, 24 December 2016, 11:04:51 »
A JD40 & a Minorca, my first hand wired. I'm still not very good at scrounging keycaps to fit them but they type just fine.  ;)
Both have Gateron reds.
156044-0
REΛLFORCE
« Reply #560 on: Sat, 31 December 2016, 22:57:11 »
minivan alps prototype <3 thanks evangs
potato, O key stem was broken :\
Need to reseat the semicolon switch, it's not flush.
3d printed ziptyze case :p
Offline dante
« Reply #561 on: Sun, 01 January 2017, 00:18:47 »
This is precisely why I get nervous considering a Lightcycle Alps set.  The argument is "well how often do you change keycaps?"  All it takes is a single  stem breaking and it's like someone backed into your new car.
« Reply #562 on: Sun, 01 January 2017, 00:34:07 »
yeah oh well, already put in my ticket to get it replaced, but who knows how long that'll be.
Offline tomboy
« Reply #563 on: Sat, 14 January 2017, 15:47:32 »
Atreus with MOD-Ms (my first build): http://imgur.com/a/DJkgG
« Reply #564 on: Wed, 25 January 2017, 00:31:32 »
At some point this'll have a case but for the time being a painted piece of wood works.
Offline KetchyKech
« Reply #565 on: Thu, 26 January 2017, 21:40:48 »
x-post
potato of new work keyboard  ;D
 :thumb:
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #566 on: Thu, 26 January 2017, 21:45:06 »
x-post
 :thumb:
That USB cable is remarkable short. Quite fitting for the 40% ;)
Offline KetchyKech
« Reply #567 on: Thu, 26 January 2017, 22:14:29 »
x-post
 :thumb:
haha yeah, my macbook uses usb-c so i attach it to an adapter =P
also works great for those work dells in the office space that have the usb on the very front of the pc
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #568 on: Thu, 26 January 2017, 22:46:05 »
x-post
 :thumb:
Hah, mac's and all their fancy adapters =P
Offline funderburker
« Reply #569 on: Fri, 27 January 2017, 05:25:40 »
x-post
 :thumb:
Nice board. I presume it's not meant for programming or at least not primarily? Would you be so kind and share your keymapping? Don't have a JD45 but this makes me think about getting one. :D
Keyboard design by Skepur
Offline KetchyKech
« Reply #570 on: Fri, 27 January 2017, 09:48:57 »
x-post
 :thumb:
Nopeee~ No programming here-- I'm an immigration attorney in the states so mostly word processing  :))
Heres my current layout (still a WIP) -- I used one that someone had shared over on the JD45 thread to test it out, and liked it!
Offline Dvoraknolegends
« Reply #571 on: Wed, 08 February 2017, 21:57:51 »
The JD40 is great but it doesn't work with dvorak so I made my own 42%.  :thumb:
I'd love to see it next to a JD40 at some point!
Are you interested in making one of these for me-- I already have switches, keycaps and USB cable (I'd need the stabilizers). This is just the sort of rig I need, a 40% that's Dvorak compliant. In fact if you make it an ortholinear PCB that would be even better.
Offline Twinguin
« Reply #572 on: Wed, 08 February 2017, 22:01:59 »
My little ones
Vortex Core w/ MX Red and JD45 w/ MX Blue and some PMK DSA caps
There is a curse. They say: May you live in interesting times!, Terry Pratchett
Popsicle KUL ES-87 (MX Blue, DSA) | Sun Ultracomputing Pok3r (MX Brown, DSA) | Nuclear WASD 100% (MX Brown, SA) | Gulf Pok3r (MX Clear, DSA) | Granite JD45 (MX Blue, DSA) | Coffee Core (MX Red, DSA) | Lime Pok3r (MX Clear, SA) | Canvas Vibe (MX Silent Red, XDA)
« Reply #573 on: Wed, 08 February 2017, 22:13:01 »
I don't have any extra PCBs but my friend who built one may want to sell it. There will never be an ortholinear MA42 unless someone else decides to design one, I've never been a fan of non staggered boards.
If you're interested in the layout I have a second board (MA52) that I should be making later this year.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #574 on: Wed, 08 February 2017, 22:25:21 »
My little ones
That's a nice colour scheme. I love orange :D
Offline Twinguin
« Reply #575 on: Tue, 14 February 2017, 05:47:02 »
Thanks, need to take a new picture of the family.
Sent from the road.
« Reply #576 on: Fri, 03 March 2017, 21:48:06 »
Cool! Sorry, just seeing this now. Let me know, otherwise I'll just get a Planck kit. I'm not sold on the ortholinear layout, but Dvorak is indeed crucial for me.
« Reply #577 on: Fri, 03 March 2017, 22:49:25 »
Swapped my caps around to use some artisans I haven't used in a while/ just received.
Good one with the "number row", haha.
By the way, we can nix my interest in your friend's Dvorak board: I just discovered the JD45 layout and it's just perfect. The kit is available at Mechanicalkeyboards.com for $200.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #578 on: Sat, 04 March 2017, 00:03:14 »
I really do love my alps minivan... i just need to sit down and reprogram it so I can remember where I put everything.
-Dana
Offline Sempre
« Reply #579 on: Sat, 04 March 2017, 00:54:46 »
Beautiful  :thumb:
Offline OfTheWild
« Reply #580 on: Sat, 04 March 2017, 01:51:54 »
Thanks! Not much of that is actually my doing... I simply assembled what Evan built! Such a great board though.
-Dana
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #581 on: Sat, 04 March 2017, 15:56:58 »
Fantastic
Offline USER9127
« Reply #582 on: Sat, 04 March 2017, 18:04:53 »
I saw this board at the NC meetup. Was one of the nicest ones there.
Man, a build like that with greens....
Offline AlexAtPanc
    • Panc Interactive
« Reply #583 on: Sun, 05 March 2017, 09:15:58 »
Just dyed some caps for my Sebright and Minorca mainstays:
Offline Rwhite025
  • I love 40%
« Reply #584 on: Fri, 17 March 2017, 11:09:57 »
Here is my jd40, I hope I am not late.
I was looking too hard, when I should have been looking more easy.
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #585 on: Mon, 20 March 2017, 21:40:13 »
Great JD40!!!!!
Offline AlexAtPanc
    • Panc Interactive
« Reply #586 on: Tue, 21 March 2017, 13:09:17 »
PCB version of the Minorca getting prototyped as we speak.
Offline yangdigi
« Reply #587 on: Wed, 05 April 2017, 09:19:32 »
A new one. I name it YDP40. The pics below are with a prototype Acrylic case.
I am still waiting for my keycaps. Later I will add more photos about Aluminum sandwich case and Aluminum CNC case.
164931-0
164933-1
164935-2
164937-3
« Reply #588 on: Wed, 05 April 2017, 12:35:25 »
Remind me of the terminus Mini, but with no bezel :D
Offline menuhin
« Reply #589 on: Wed, 05 April 2017, 12:52:40 »
I like some higher profile case with bezel - which does not exist in the market right now for Planck.
IBM M13 black
HHKB Pro 2 HasuBT
Offline ctzn_voyager
« Reply #590 on: Wed, 05 April 2017, 22:09:07 »
The Van with Devlins
Offline yangdigi
« Reply #591 on: Wed, 12 April 2017, 18:21:43 »
add two more pics with some sample XDA keycaps.
165614-0
165616-1
Offline KetchyKech
« Reply #592 on: Wed, 12 April 2017, 18:24:07 »
what in the wurld are these devlins oO;; pretty neat lookin'
Offline tomboy
« Reply #593 on: Wed, 12 April 2017, 18:36:28 »
this is the set in question I think: http://www.ukkeycaps.co.uk/product/retroist-k-series-planck-double-shot-keyset
Offline flashquark
    • Flashquark.com | Mech Key Depot
« Reply #594 on: Sun, 16 April 2017, 11:22:02 »
Perhaps it may seem pretty ordinary and blank... but I love my AMJ40.
Let's Split is peeking around in the background as well!
https://flashquark.com | Keyboards, Keycaps, Switches, and other MK accessories.
Offline smithyithy
  • a l p s
« Reply #595 on: Wed, 19 April 2017, 07:21:03 »
Oh that looks great, I was tempted to grab the Devlin caps for my Mech Mini and maybe source the other caps from peoples grab bags etc.. Are they SP SA blanks that you've used for the mods?
KBD75; Alps64 trio; some other stuff
« Reply #596 on: Wed, 19 April 2017, 16:00:43 »
3 of my 40s
Will add photo later
« Last Edit: Wed, 19 April 2017, 16:11:24 by William_S_Jones »
« Reply #597 on: Wed, 19 April 2017, 17:05:08 »
3 of my 40s
« Last Edit: Wed, 19 April 2017, 17:11:55 by William_S_Jones »
Offline mrboovn
« Reply #598 on: Wed, 19 April 2017, 17:36:03 »
3 of my 40s
Nice collection .The red one looks really nice with keyset .
« Reply #599 on: Wed, 19 April 2017, 17:42:22 »
3 of my 40s
Thanks, appreciate it. I thank Bunnylake for the JTK Sophomore keycap sets & 1upkeyboards for the Red Carbon fiber JD40 & LeandreN for the silver "youtube build" carbon fiber JD40!
edit: JD45 artisans - Thanks HKP for the hot pink Raven & JChan94's KeyClack for the Night Unicorn!
« Last Edit: Wed, 19 April 2017, 17:53:04 by William_S_Jones »
