Author Topic: And to think MX Super Blacks would be heavy...  (Read 14603 times)
Offline Zeal
    • Zeal Generation Inc.
« on: Sun, 26 January 2014, 20:51:17 »
So I using my ratcheting screwdriver yesterday, and the end that held the screw bits popped off and broke. Inside I found a spring...
Just from looking at the coils, I knew that it would be a stiff spring. Trying to depress it was nearly impossible without a housing. So I brought it back home and decided to play around with it, seeing if it would fit in an MX Switch  :p
MX Blue spring on the left, Screwdriver spring on the right. It's a tad thicker and taller than regular MX Springs, but it fits in an MX switch.
Top View:
Depressing the switch:
Regular coins/small weights wouldn't be able to depress the switch. Even a 13" macbook air couldn't depress it all the way, and that thing weighs 1350g+  :eek:
What should I do with the spring? I think I'll name it Stiffy  :))
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: And to think MX Super Blacks would be heavy...
« Reply #1 on: Sun, 26 January 2014, 20:53:39 »
Huehueuhuehue "Stiffy"  ;D
« Reply #2 on: Sun, 26 January 2014, 20:53:53 »
 :o
Offline HPE1000
  • Keycap Paparazzo
« Reply #3 on: Sun, 26 January 2014, 20:57:29 »
Haha, I have been wanting a super black for awhile now. But maybe I just need this  :rolleyes:
Offline jonathanyu
« Reply #4 on: Sun, 26 January 2014, 20:58:42 »
maybe this should call ultra black...
« Reply #5 on: Sun, 26 January 2014, 21:03:13 »
Mega black?
Offline Zeal
« Reply #6 on: Sun, 26 January 2014, 21:05:51 »
Mega black?
MX Super blacks actuate at 150g, this spring probably actuates at 10x the weight  :eek:
I'm really curious what the bottom out force of it is...
Offline redskull
« Reply #7 on: Sun, 26 January 2014, 22:04:27 »
someone should try getting more of these, put them all together on a complete board and then do a typing test. see how much wpm he/she can blast out of dem stiffies.  ;D
Offline Air tree
« Reply #8 on: Sun, 26 January 2014, 22:05:58 »
My shrimps for fingers probably couldn't depress one of them while typing :P
Offline Zeal
« Reply #9 on: Sun, 26 January 2014, 22:09:46 »
I think my pinkie would die before I could complete a run of 10fastfingers.
You really have to focus a lot of strength on each key...I would probably average under 30WPM if I used these springs on the alphas. I usually average ~110WPM
Edit: I just tried actuating the keychain with my pinkie. It hurts ;-; I don't think it even went past 2mm without using my arm's weight to press it down.
Offline redskull
« Reply #10 on: Sun, 26 January 2014, 22:12:49 »
lulz. sounds like so much fun trying to use these. do put them all on a keyboard, and prank someone with it.  :))
Offline Zeal
« Reply #11 on: Sun, 26 January 2014, 22:15:30 »
Only have 1 pinkie-killing spring unfortunately.
Who needs a "Windows" lock when you have this spring?  :p
Offline tbc
« Reply #12 on: Sun, 26 January 2014, 22:21:53 »
megazord black lol
is this the counter to the steel brobot? ;p
Offline Zeal
« Reply #13 on: Sun, 26 January 2014, 22:25:42 »
megazord black lol
Steel brobot got nothin on this spring!
Bring on the lead Brobot!!!
Offline Air tree
« Reply #14 on: Sun, 26 January 2014, 22:32:03 »
I don't even use my pinkie to type.  :p
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #15 on: Sun, 26 January 2014, 22:38:52 »
Omega blacks
Offline dante
« Reply #16 on: Sun, 26 January 2014, 22:50:51 »
Super MX Blacks wouldn't be complete if they were not tied to the worst keyboard layout possible:
link
Offline tbc
« Reply #17 on: Sun, 26 January 2014, 23:10:51 »
omfg....i didn't have to read the article to see how bad having all the vowels on the bottom row is.
Offline Linkbane
« Reply #18 on: Sun, 26 January 2014, 23:11:14 »
Put the Giga-Blacks on a board and sell it in classifieds as a one-of-a-kind unique board for $900, some idiot will snap it up.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline Zeal
« Reply #19 on: Sun, 26 January 2014, 23:30:38 »
link
If anyone can type 100+WPM with that layout, then you would be my hero.
Only have 1 spring. If I had enough for a keyboard, I'd definitely make one for kicks.
« Last Edit: Sun, 26 January 2014, 23:36:44 by Zeal »
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #20 on: Mon, 27 January 2014, 00:28:46 »
You need to prank someone with that spring.  You should put it in either the E or the spacebar.
« Reply #21 on: Mon, 27 January 2014, 00:39:24 »
Or backspace :))
Offline Zeal
« Reply #22 on: Mon, 27 January 2014, 00:41:16 »
Or backspace :))
Backspace would definitely be the killer! :p
Now I wish I had more of these springs...
Offline YoungMichael88
  • HHKB Wannabe
« Reply #23 on: Mon, 27 January 2014, 00:51:19 »
I would put it on Z or X. So they actually type a bit before running into it.
Offline tbc
« Reply #24 on: Mon, 27 January 2014, 02:05:33 »
^ are you trying to cause a work injury? lol
  • HHKB Wannabe
« Reply #25 on: Mon, 27 January 2014, 02:09:10 »
Maybe
Offline phoenix1234
« Reply #26 on: Mon, 27 January 2014, 02:16:35 »
We should troll our boss with this spring.
Give him/her they gold keycap with this 1.5kg-spring modded on that $ position.
 :eek:
I like linear switches
Offline retsteel
  • Hmmm... I guess I'm here again.
« Reply #27 on: Mon, 27 January 2014, 03:01:26 »
I would definitely be that idiot. I've wanted a topre board for a long time, I think I want this more.
Offline hoggy
  • * Ergonomics Moderator
« Reply #28 on: Mon, 27 January 2014, 03:07:59 »
I like the idea of a switch that you'd have to thump down on with your fist to activate, but I'm more of a laid back kind of guy.
Offline baldgye
  • Will Smith Disciple
« Reply #29 on: Mon, 27 January 2014, 06:42:58 »
Finally someone has created a switch capable of holding the steel brobot
Offline bazh
« Reply #30 on: Mon, 27 January 2014, 07:05:06 »
Steel is nothing, bring on the lead brobot
HHKB Pro2 white
Newbie again
Offline deSheol
  • Thorpe
« Reply #31 on: Mon, 27 January 2014, 07:30:48 »
Rofl
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #32 on: Mon, 27 January 2014, 07:48:42 »
Spacebar would be ideal -- I've always wanted to see someone use their forearm to actuate the spacebar while typing.  :thumb:
And when you're done typing with it for a week, you can crush cinder blocks with your fingers.
Quote from: Samuel Adams
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #33 on: Mon, 27 January 2014, 12:10:14 »
Preparation...
A Ghost From The Past
Offline Melvang
« Reply #34 on: Mon, 27 January 2014, 13:11:50 »
Or put it on the backspace and they will learn to never type the wrong key again.
Offline Zeal
« Reply #35 on: Mon, 27 January 2014, 13:15:08 »
The ultimate way in learning to type without typos!  :eek:
