Author Topic: How do I lube my CM Storm Quickfire TK (Red Switches)?  (Read 3872 times)
Offline magohipnosis
« on: Mon, 27 January 2014, 16:28:26 »
I heard that if you lube your keyboard switches they may feel better.
Now, how do I lube my switches?
Thanks in advance.
Offline Pacifist
  • on hiatus
Re: How do I lube my CM Storm Quickfire TK (Red Switches)?
« Reply #1 on: Mon, 27 January 2014, 16:29:40 »
Desolder switches, open them, lube stem, put back together, solder
« Reply #2 on: Mon, 27 January 2014, 16:33:31 »
Are you sure there's no way to lube them without desoldering?
Offline Linkbane
« Reply #3 on: Mon, 27 January 2014, 16:38:12 »
Because the TK (like most) is a plate-mounted board, it necessitates desoldering. If you had one of those switch removal tools, which can be DIY'd, you might be able to open it without desoldering, but I'm not sure about the specifics.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #4 on: Mon, 27 January 2014, 16:40:43 »
The switch top removal tools only work on plate mounted boards that have the custom cutouts which allow the tops to be removed. So far no factory plate allows this.
Some people have tried spraying lube into the switches however this method is not recommended.
Offline HPE1000
  • Keycap Paparazzo
« Reply #5 on: Mon, 27 January 2014, 16:59:36 »
Honestly, if you don't want to take the switches off the board to begin with you shouldn't be lubing. Lubing takes a lot of time depending on how you do it.
Your boards switches are plate mounted so you will have to desolder.
Offline 1pq
  • Hipster Doofus
« Reply #6 on: Mon, 27 January 2014, 17:11:58 »
If you want to experiment with lubing/modding, you should buy an old cherry pcb-mounted board and fool around with that. Modding plate-mounted boards is annoying af unless you have a custom plate.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline Linkbane
« Reply #7 on: Mon, 27 January 2014, 21:24:55 »
Oh, okay, thanks for the information.
Offline Pacifist
  • on hiatus
« Reply #8 on: Mon, 27 January 2014, 21:25:35 »
But once u desolder u can file down the plate. somebody here has done that before
Offline Pac Caps
  • Its almost a pallindrome
« Reply #9 on: Mon, 27 January 2014, 22:03:08 »
You need a custom made plate to do so. No big keyboard maker has done that yet, because it adds almost unncessary cost, as a majority of users won't be modding the board.
Want to be a cap maker
Offline Dreamre
    • kbdlife
« Reply #10 on: Mon, 27 January 2014, 22:34:03 »
Filing down the plate is going to take too much time and effort...
Offline Pacifist
  • on hiatus
« Reply #11 on: Mon, 27 January 2014, 23:01:03 »
Somebody on GH has already done that. Lubing keyboards also takes a lot of time and effort, but we still do it.
