Author Topic: [Solved] Stripped screw in my Pure Pro  (Read 4202 times)
Offline FrostyToast
  • Litshoard
« on: Tue, 28 January 2014, 16:17:45 »
I recently got my a 60% aluminium case and I was planning to put it on my Pure Pro.
However I somehow managed to strip one of the screws to the point where the little Phillips hole turned into a circle. (don't ask me how I got it this bad)
Here is a link to an image I found to show you how much clearance I would have.
Do you have any ideas for how to fix this?
Update: I fixed this by maybe possibly tearing the side of my case open to get at the screw since it was on the very side.... A bit brutal but hey it worked!
« Last Edit: Thu, 30 January 2014, 07:30:11 by FrostyToast »
Quote from: elton5354
Offline longweight
  • philanthropist
Re: Stripped screw in my Pure Pro
« Reply #1 on: Tue, 28 January 2014, 16:26:30 »
Drill it out.
« Reply #2 on: Tue, 28 January 2014, 16:28:35 »
You might find some helpful hints from this thread
http://geekhack.org/index.php?topic=51162.0
Offline FrostyToast
  • Litshoard
« Reply #3 on: Tue, 28 January 2014, 16:47:10 »
Slotting would seem to be the simplest method. Do have any suggestions on how I could do this?
Offline FrostyToast
  • Litshoard
« Reply #4 on: Wed, 29 January 2014, 22:05:34 »
Since I felt I wasn't getting anywhere I had to go to some 'drastic' measures and tore up my case.
Yeah you heard me... Since the stripped screw was on the very side of the case, I decided to tear the side of the case and unscrew it from the side with pliers as there was more clearance.
The process turned out great and I have now installed my aluminium case.
I might plan on sawing off all of the sides of my keyboard to make a super low profile case later.
« Reply #5 on: Wed, 29 January 2014, 22:37:29 »
a rubber band between the screw and screwdriver would have done the job
Offline FrostyToast
  • Litshoard
« Reply #6 on: Wed, 29 January 2014, 23:56:37 »
I already tried the rubber band and I believed that I mentioned in the op that the area in the head was essentially a circle. There was basically nothing to grip onto anyway.
I also tried the rubber band method a couple of times before anyway.
« Reply #7 on: Wed, 29 January 2014, 23:57:29 »
cheap screws then :(
Offline terran5992
  • One With The Cup Rubber
« Reply #8 on: Wed, 29 January 2014, 23:57:54 »
Wow thats gonna be really difficult to remove.
Have you tried with a flat head?
« Reply #9 on: Wed, 29 January 2014, 23:59:27 »
he already unscrewed it
Offline terran5992
« Reply #10 on: Thu, 30 January 2014, 00:01:58 »
Meh bad D:
Sowee demik
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #11 on: Thu, 30 January 2014, 00:17:55 »
Super-glue usually works for small screws...
A Ghost From The Past
Offline FrostyToast
  • Litshoard
« Reply #12 on: Thu, 30 January 2014, 07:31:38 »
Hey man, ripping open the side of your case is the manly way to go. Let's just hope this doesn't happen now that I have an aluminium case  :))
(also thanks for the advice, I will use that next time)
