Author Topic: IBM Space Saver KB goes haywire on Belkin KVM Switch  (Read 1381 times)
Offline Clueless in Seattle
« on: Mon, 03 February 2014, 10:56:21 »
Hi!
I'm trying to get an IBM model M space saving (84-key) keyboard to work with a Belkin 4 port Model F1D5104T KVM switch.
The problem I'm having is that many of the keys are either dead or cause strange cursor behavior when I connect the keyboard to my computers via the KVM switch.  But, the same keyboard works fine when connected to a couple of the same computers via a MINIVIEW GCS12 2 port KVM switch.
Here are the keys that type normally via the Belkin switch:
abcdefgh     n pqrst vwxyz
The gaps indicate keys that are either dead or cause strange cursor behavior.  For example the "u" key acts sort of like a backspace key causing the cursor to move backward on the line.
I'd be grateful for some advice on where to start in troubleshooting this problem.  I've had to resort to a "squishy" key Keytronic  full width keyboard that hogs way too much space on my tiny computer table.
Will in Seattle
a.k.a. "Clueless"
Will in Seattle
a.k.a. "Clueless"
Offline Parak
Re: IBM Space Saver KB goes haywire on Belkin KVM Switch
« Reply #1 on: Tue, 04 February 2014, 11:35:51 »
Most likely it's a lack of power. Model Ms are infamous for being ps/2 power hungry, which leads to issues when it's not being supplied enough, and KVMs can be entirely random about how much power they supply via ps/2. I'd suggest trying one of the recommended usb adapters (if a review mentions a Model M working with it then it's good) and using usb ports instead.
