Author Topic: 60% with Matrix Layout?  (Read 4297 times)
Offline tricheboars
  • Keyboards are Important!
« on: Mon, 03 February 2014, 13:19:05 »
Has anyone tried to make a 60% with a matrix layout?  People seem to be really over the moon with the matrix layout regarding the ergodox so i am just wondering if we have tried to implement that layout elsewhere?
Re: 60% with Matrix Layout?
« Reply #1 on: Mon, 03 February 2014, 13:25:07 »
Offline tricheboars
« Reply #2 on: Mon, 03 February 2014, 14:33:54 »
just found this:
i think acidfire made it. pretty awesome although not a perfect matrix layout due to a little bit of vertical staggering.
Offline hasu
  • @tmk
« Reply #3 on: Mon, 03 February 2014, 14:34:50 »
humble hacker?
Offline tricheboars
« Reply #4 on: Mon, 03 February 2014, 14:51:21 »
humble hacker?
hasu! you are right the Humble Hacker has a matrix layout. i totally forgot about that awesome project! it isnt as cool as the ergodox but that board is a great story.
Offline daerid
    • Rossipedia
« Reply #5 on: Mon, 03 February 2014, 15:41:38 »
just found this:
That's a 70% design based off the ErgoDox I challenged AcidFire to make, I don't think that the board pictured actually works, it was more a proof of concept (but it will be part of his Nexus system, as far as I understand it).
Offline tricheboars
« Reply #6 on: Mon, 03 February 2014, 16:14:27 »
2014 is the year of the matrix layout. you heard it right here first folks.
« Reply #7 on: Mon, 03 February 2014, 17:39:16 »
Matrix layout is bollocks.. Columnar layout, with proper column offset is nice.
One way to get a mechanical with matrix layout and being 60% is to get a programmable POS keyboard of sufficient size that has diodes for NKRO. Access-IS comes to mind.
Offline SonOfSonOfSpock
« Reply #8 on: Mon, 03 February 2014, 22:05:00 »
Is it the columnar aspect of the Ergodox people don't like? I'd think it would be all the other non-alphabet keys moving around that would bother them. A 60% with columnar layout sounds like it'd be the Typematrix but with mechanical switches.
Offline yasuo
  • spanengan puyeng newbie
« Reply #9 on: Mon, 03 February 2014, 22:27:26 »
no..no,for 60% i prefer symm sgg than matrix :-X
Logitech MK220 Colemak DH
Offline kod
« Reply #10 on: Mon, 03 February 2014, 22:31:02 »
Humble hacker looks like a really nice idea.  What ever happened with that - did anyone make pcbs in quantity?
Offline Oobly
« Reply #11 on: Tue, 04 February 2014, 02:13:49 »
My preferences:
1. Separated (tentable) vertically staggered columns with angled thumb clusters (like my DIY board and AcidFire's Nexus)
2. Separated (tentable) vertically staggered columns with thumb buttons (like ErgoDox)
3. Combined (flat) vertically staggered columns with thumb buttons (like the picture above)
4. Combined vertically staggered columns / Symmetrical stagger  (like this: http://i54.tinypic.com/adyfbs.jpg)
5. Matrix
6. Horizontal stagger (normal QWERTY)
So for me, matrix layout is only one step better than "normal" layout. I do have a problem with the ErgoDox and possibly nexus, though: The pinkie columns need more offset.
That is all..
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline tricheboars
« Reply #12 on: Tue, 04 February 2014, 10:02:23 »
What about just using lighter switches for the pinky column?
Offline Oobly
« Reply #13 on: Tue, 04 February 2014, 13:10:34 »
That won't shift it into position under the fingertip, just make it lighter to press. I don't really like "variable weight" boards.
Offline tups
« Reply #14 on: Sat, 22 February 2014, 11:59:11 »
Also the kind of thing I'm looking for (though preferably symmetric or columnar stagger like Oobly says).
Are there really no retail keyboards approximating that description?
« Reply #15 on: Sat, 22 February 2014, 14:53:46 »
The TECK https://www.trulyergonomic.com/store/index.php isn't 60% as far as key count, but it's 60% as far as width is concerned.
