Author Topic: phantom compatible switches  (Read 3651 times)
Offline jgrade
« on: Tue, 04 February 2014, 11:31:36 »
Hi,
Does anyone know if the Futaba Switches are compatible with the Phantom PCB?
I have this switches http://deskthority.net/wiki/Futaba_clicky_switch that i got from a Samsung 1010ds keyboard.
Offline damorgue
    • Personal portfolio
Re: phantom compatible switches
« Reply #1 on: Tue, 04 February 2014, 11:51:40 »
Hi,
Nope, they are not compatible with that PCB. If you take a look at the pins of MX switches you will notice that they are offset in both X and Y whereas Futaba have their pins at the edges.
Offline jgrade
« Reply #2 on: Tue, 04 February 2014, 12:04:55 »
Hi,
thanks
« Reply #3 on: Tue, 04 February 2014, 12:54:56 »
Only Cherry MX (an clones of MX) will work on ErgoDox.
Someone discovered that you could sort of fit Alps switches on the PCB, but you would have to design and make a new plate and case because 1) Alps have different dimensions than Cherry, and 2) the switches wouldn't be centred on the old switch positions.
« Reply #4 on: Tue, 04 February 2014, 13:03:22 »
Nobody mentioned ergodox.
« Reply #5 on: Tue, 04 February 2014, 13:08:09 »
That never stops TP4 :D
« Reply #6 on: Tue, 04 February 2014, 13:38:52 »
True dat.. *smacks forehead*.
Too little sleep... or too much.
Or the Topre fanboys ...
Offline MJ45
  • HHKB Pro
« Reply #7 on: Tue, 04 February 2014, 14:22:50 »
Why would one want to use Futaba switches anyway?
Offline jgrade
« Reply #8 on: Tue, 04 February 2014, 14:28:34 »
because i have them laying around
Offline strict
  • TKL Zealot
« Reply #9 on: Tue, 04 February 2014, 19:24:47 »
This was my first thought when I read the OP. I got a board with Futaba switches for free a few weeks ago and just threw it away.  :(
« Reply #10 on: Tue, 04 February 2014, 21:32:27 »
Complicated futaba vintage linears are quite nice. I'd love to use them on a phantom board. Sadly, they will not work.
Offline strict
  • TKL Zealot
« Reply #11 on: Tue, 04 February 2014, 22:03:44 »
I would be interested to try Linear Futaba switches. The ones on the keyboard I mentioned were clicky tactile switches, but they only clicked on switch return. Essentially the total opposite of Cherry blues. It was very awkward feeling. Coupled with some nasty grime and discoloration I deemed it not worth my while.
Offline jgrade
« Reply #12 on: Wed, 05 February 2014, 04:05:30 »
the futaba switches are faceplate mounted (i think) what if i just connect the switches to the phantom with wire? are the switches going to be too louse?
Offline Proc31
« Reply #13 on: Wed, 05 February 2014, 10:07:06 »
If you want to wire every single switch by hand why even bother with the PCB?
Offline esoomenona
  • Gnillort?
« Reply #14 on: Wed, 05 February 2014, 10:26:28 »
True. Wire them in a matrix to a teensy. There are guides here for that.
