Author Topic: Cheap Wireless Mouse with Easy to Press/Soft Middle Scroll Button  (Read 3710 times)
Offline morpheus
« on: Wed, 05 February 2014, 08:47:02 »
As the subject states:
I'm looking for a cheap wireless Mouse with Easy to Press/Soft Middle Scroll Button.
Over the years, I've used a lot of cheap mice, and a lot of them had a stiff middle/scroll button, or it was too mushy.
I'm wondering if anybody here had any advice for me.
Offline morpheus
Re: Cheap Wireless Mouse with Easy to Press/Soft Middle Scroll Button
« Reply #1 on: Wed, 05 February 2014, 08:50:48 »
I should add, I'm looking for a crisp, solid response, while not being stiff or mushy, if that makes any sense.
Also, it has to be full size mouse, not the dinky little ones you use for notebooks.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Wed, 05 February 2014, 23:11:44 »
You'd end up spending more money on the mice you go through. Wireless mice rarely last, at least in my experience and seemingly most other people.
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Sat, 08 February 2014, 17:35:23 »
I'm *very* picky about third button on mice, due to malformed middle finger. So far, I've found two mice with soft wheel press: CM Storm Xornet and WMO. Rubbery wheels on Zowie mice, Belkin Nostromo n52te and new Roccat mice (such as Savu) are okay too. Unfortunately, I'm not aware of anything else, but it doesn't really matter, because I usually remap some thumb button to 3rd button.
