Author Topic: IBM / Honeywell rubber dome keyboard  (Read 2449 times)
Offline ed_avis
« on: Mon, 10 February 2014, 01:43:06 »
Re: IBM / Honeywell rubber dome keyboard
« Reply #1 on: Mon, 10 February 2014, 07:40:30 »
hyperlink: http://www.ebay.com/itm/370999063870
It's those 104 key "unsaver" terminal layout rubberdome KBs. They are reportedly very good for domes.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Mon, 10 February 2014, 08:32:31 »
But it's in no way worth $70.  I picked one up for $10 last year when there was a seller who had a bunch and was asking $50.  Note the nonstandard keys.
The thing is built like an F.  Very solid.  Has a boatload of dip switches inside and I went through all the settings, couldn't get it to talk to a PC.  Of course would work with a converter.
May have other plans for the case...
« Reply #3 on: Mon, 10 February 2014, 21:08:48 »
Pretty sure it'll work with soarer's converter.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Tue, 11 February 2014, 11:45:48 »
100% sure it'll work with Soarer's converter.
kishy.ca
