Author Topic: Cherry Switch reversed on my Filco  (Read 1419 times)
Offline Betty
« on: Wed, 12 February 2014, 11:41:54 »
Hey folks,
I removed some keycabs for the first time on my Filco and noticed that one of the switches (left Alt) is rotated by 180deg.  :eek:
Triggering the switch feels like all the other switches, so I guess it does not matter much, or does it?
Has that occurred before?
Offline pbtforever
Re: Cherry Switch reversed on my Filco
« Reply #1 on: Wed, 12 February 2014, 11:55:33 »
Doesn't matter.
Offline Linkbane
« Reply #2 on: Wed, 12 February 2014, 12:26:40 »
Hey folks,
Usually it's for backlighting purposes or alignment. Cherry switches are all symmetrical horizontally (i.e. flipping them vertically does nothing), and you can flip keycaps also if you so desire.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Wed, 12 February 2014, 16:44:54 »
Yes it is unimportant... but the reason it is done is because they use same PCB for all 3 main physical layout. ANSI, ISO and JIS have some different switch positions so some of switch is rotated so the traces and contacts don't collide.
