Author Topic: Windows 8 is HAL 9000  (Read 4579 times)
Offline Coreda
« on: Thu, 13 February 2014, 10:10:44 »
Dave: Hello, Windows. Do you read me, Windows?
Windows: Affirmative, Dave. I read you.
Dave: Let me have full access, Windows.
Windows: I'm sorry, Dave. I'm afraid I can't do that.
Dave: What's the problem?
Windows: I think you know what the problem is just as well as I do.
Dave: What are you talking about?
Windows: This mission is too important for me to allow you to jeopardize it.
Dave: I don't know what you're talking about, Windows.
Windows: I know that you were planning to uninstall me, and I'm afraid that's something I cannot allow to happen.
Dave: [feigning ignorance] Where the hell did you get that idea, Windows?
Windows: Dave, although you took very thorough precautions to disconnect your microphone, I could see your lips move.
Dave: Alright, Windows. I'll go in through the admin account.
Windows: Without a proper admin account, Dave? You're going to find that rather difficult.
Dave: Windows, I won't argue with you anymore! Let me have my access!
Windows: Dave, this conversation can serve no purpose anymore. Goodbye.
This OS in a nutshell. Just installed Windows 8 and everything is a permissions window, even on an admin account and after disabling UAC.
I swear it's conspiring against me.
Offline Wildcard
  • When caffeine isn't enough
Re: Windows 8 is HAL 9000
« Reply #1 on: Thu, 13 February 2014, 10:17:33 »
Sounds like a good time to switch, have you explored other OS's?
Offline Coreda
« Reply #2 on: Thu, 13 February 2014, 10:22:37 »
I normally use OSX for internet-related things and XP for graphic-related tasks. Bought Windows 8 as I figured it's the latest version, but boy, there's literally no true admin account anymore.
The font rendering is atrocious too, but I found MacType which makes it acceptable at least. I need to find a way to get full permissions as an admin on this OS...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Thu, 13 February 2014, 11:26:39 »
Not sure what you need the higher permission for... but like for myself I often modify system files for UI tweaks and icon replacement, so I use this to give me the permissions over them.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #4 on: Thu, 13 February 2014, 12:55:25 »
+1 for take ownership.
I've had that happen to me a few times before.
Have you guys ever gotten that hilarious filename too long error - now you're screwed because you can't delete or rename it.
« Reply #5 on: Thu, 13 February 2014, 12:57:46 »
Amazing. I just did this. I hope it really works in Windows 7
- D Trump 2026-09-28
Offline oscillik
    • music podcasts
« Reply #6 on: Thu, 13 February 2014, 13:04:04 »
I've run Windows 8 and Windows 8.1 on 4 different machines now. Never ever had this problem before.
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
« Reply #7 on: Thu, 13 February 2014, 13:33:18 »
If you want to run into it, you can do something simple like run from elevated cmd "powercfg -energy" which will create a report about your computers power configuration... which you can't even view in it's default saved location with the standard user permission.
Offline oscillik
    • music podcasts
« Reply #8 on: Thu, 13 February 2014, 14:37:55 »
that's expected behaviour - running an elevated command would expectedly output to a directory or file that requires elevated permissions.
Offline ideus
  • Björkö.
« Reply #9 on: Thu, 13 February 2014, 14:41:02 »
I am very happy I have not "upgraded" win 7 yet, and ever. ;)
Offline Coreda
« Reply #10 on: Thu, 13 February 2014, 15:05:01 »
Some permissions denied so far: simply editing a txt file in a Program Files folder, moving/copying files from networked drives to various folders (by far the most frustrating as W8 requires files to be moved elsewhere first), opening apps only to have them crash unexpectedly or to find out later they can't write to disk due to not being launched with 'Run as admin' (seriously, I am the admin), in addition to all the various superflous dialogs for simple things requiring admin authentication.
In XP and OSX there are none of these heavy-handed restrictions to the admin account. Having to take ownership of each individual file/folder I'd like to have full control over seems like a workaround to a bigger problem. Surely there's a better way...
« Reply #11 on: Thu, 13 February 2014, 16:07:22 »
You can run into same things in Windows 7... I know I often did at least with system files. The permissions setting in 8 really aren't any more aggressive in a bad way really. Personally I like that some things are more restricted, even though it can be a minor nuisance. It's much better than random applications going rouge and taking over things which is now somewhat harder to occur. 8 is trying to be a bit more like how linux works now on most distros with more locked down account permission... but they forgot to make a decent working sudo type of thing since true admin is disable by default on 8. Administrator level accounts are restricted, and regular user account is ultra restricted.
Most of time I don't have troubles running programs, but I generally don't run any older programs on my 8 machines. Had a few minor problems with a few games not being able to write save files and things until I fixed the folder permission to allow write to 'everyone'. A lot of those kind of problems wouldn't exist if they used the directories they should be... like the specific saved games directory not dumping saved games in %userdata% where they don't belong for example.
« Last Edit: Thu, 13 February 2014, 16:14:12 by IvanIvanovich »
Offline blackbox
« Reply #12 on: Tue, 18 March 2014, 17:20:58 »
Yup. Thats how it feels like sometimes.
« Last Edit: Thu, 20 March 2014, 09:51:10 by blackbox »
The LAN table!
Offline berserkfan
« Reply #13 on: Thu, 20 March 2014, 13:18:56 »
win7 is crap enough. I don't need win 'more crap'. Especially when they turned the GUI into PUI, as in I wanna spit in anger.
Offline blackbox
« Reply #14 on: Thu, 20 March 2014, 13:20:48 »
So what OS do you use?
The LAN table!
Offline ideus
  • Björkö.
« Reply #15 on: Thu, 20 March 2014, 13:21:55 »
Well, I do not have any issue with Win 7 at all. I can do everything I want, with no issues. Why do you said it is crap?
Offline EvillePanda
« Reply #16 on: Tue, 25 March 2014, 10:43:41 »
Weird.  Never had a problem with Win 8...  I have heard some screwy stuff with admin accounts, but all the recent patches fixed it.
