Author Topic: Unusual RGB unicomp shift key  (Read 2597 times)
Offline EverythingIBM
« on: Sun, 16 February 2014, 16:03:30 »
So I ordered another set of RGB keys from unicomp, and see if you can figure out what's unusual with this shift key:
54644-0
It looks like the molds are not static then. By the way, this is not meant to deride Unicomp's quality or support-- Unicomp makes great products, and I never had any issues with their quality. The support is also awesome.
They're a great company catering to a small and unique market. I just wanted to show that funky shift key because it's neat.
Offline The_Beast
  • I like wood ಠ_๏
Re: Unusual RGB unicomp shift key
« Reply #1 on: Sun, 16 February 2014, 16:07:49 »
HoffmanMyster got the same thing when he ordered a few weeks ago, it should fit the enter key, which isn't right.....
« Reply #2 on: Sun, 16 February 2014, 16:11:51 »
Okay-- I wonder if they do have static molds, one for the shift key, and one for the enter key-- and some accidental enter keys were molded instead.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Sun, 16 February 2014, 16:14:26 »
I'm not really sure...
Since IBMs have uniform profiles, the same size mold could be used and just switching out what side get what to determine if it's a shift or enter.
Offline berserkfan
« Reply #4 on: Tue, 18 February 2014, 09:00:54 »
I'm sure there is some keyboard that would fit on. I for one, have an F XT and some really weird shift spacings.
Offline aref
« Reply #5 on: Tue, 18 February 2014, 17:17:43 »
Unicomp replaced a new keyboard I ordered that didn't work properly. The company's customer service was exceptional.
Kudos to Unicomp. But that's one strangely molded key cap.
