Author Topic: HHKB Pro 1 vs Pro 2  (Read 11719 times)
Offline ComradeSniper
  • HHKB Pro
HHKB Pro 1 vs Pro 2
« on: Wed, 19 February 2014, 13:40:13 »
I'm having trouble finding a definitive explanation so I wanted to ask: what is the difference between the HHKB Pro 1 and Pro 2, and if I wanted to obtain a Pro 1 for collecting purposes, how difficult would it be? I've only seen one or two floating around on here.
Offline AKIMbO
  • HHKBro
Re: HHKB Pro 1 vs Pro 2
« Reply #1 on: Wed, 19 February 2014, 14:24:24 »
IIRC, the Pro1 doesn't have a USB hub and the USB-in connection is situated more towards the right-hand side of the board than on the Pro2.
| KBD75 (box reds)
Offline hasu
  • @tmk
« Reply #2 on: Thu, 20 February 2014, 19:22:38 »
As AKIMbO said, Pro1 has no crappy hub, due to this you will have no problem even when hook up to iPad.
Other than that, Pro1 has classy old green mold Topre proprietary sensor chip TP1683 instead of TP1684. This is a musthave for a Topre collector :D
Though, if you are a HHK collector, I think you should go with PD-KB01 before Pro1.
« Reply #3 on: Thu, 20 February 2014, 20:23:04 »
Whoa, thanks for the information. Id love to get one some day.  :thumb:
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #4 on: Fri, 28 February 2014, 13:59:38 »
Thanks for the information Hasu!  :thumb:
I was sad when I found the my HHKB Pro 2 wouldn't work with my iPad. I'll have to hunt up a Pro 1
Offline minority
« Reply #5 on: Thu, 24 July 2014, 10:29:45 »
Could you tell the production date of this Pro1's? That's amazing!
I see some photos about Pro1's chip is changed to TP1684 on PCB... may be later version of Pro1?
Keyboard is not only switch
« Reply #6 on: Thu, 24 July 2014, 11:05:22 »
I have one from 2003 coming to me. I'll let you know which it has.
Offline Flyersfan1
  • Hi!
« Reply #7 on: Thu, 24 July 2014, 11:07:01 »
Reunited and it feels so good!  :D
Quote from: Photekq
« Reply #8 on: Thu, 24 July 2014, 11:14:00 »
Hahahaha ;) there is no staying away..
Offline minority
« Reply #9 on: Thu, 24 July 2014, 12:03:28 »
TIA :thumb:
Offline hasu
  • @tmk
« Reply #10 on: Thu, 24 July 2014, 23:02:33 »
Mine is from 2003-05 rev.A0, i think this is first lot of PD-KB300. My another Pro1 from 2004-11 rev.A2 has TP1684 as same as photo you posted.
Offline minority
« Reply #11 on: Thu, 24 July 2014, 23:43:40 »
The A0 version is awesome :cool:  Wish I can find one in the future~
« Reply #12 on: Fri, 25 July 2014, 00:27:03 »
Mine is an A0  :thumb:
Offline minority
« Reply #13 on: Fri, 25 July 2014, 00:44:10 »
Happy Lucky keyboard  :thumb:
