Author Topic: Filco Majistouch Camo usb cable shorting out  (Read 2206 times)
Offline uhlsla
« on: Mon, 24 February 2014, 16:03:12 »
Hi everyone. My Filco keyboard has a short in the cable, where can i get this keyboard fixed without shipping it back to Japan? I have emailed them already, and they tell me it will cost me almost as much to fix it as get a new one if i ship to them? Thanks.
Offline Pacifist
  • on hiatus
Re: Filco Majistouch Camo usb cable shorting out
« Reply #1 on: Mon, 24 February 2014, 16:04:11 »
Is the cable broken? Then buy a replacement filco cable from a cable maker here on GH
is the controller broken? Biphany here makes replacement ones.
Offline uhlsla
« Reply #2 on: Mon, 24 February 2014, 17:25:51 »
I think the cable is broken somewhere. if I move the cable the lights go off and on and I can't type. so I just think i need to replace the whole cable.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #3 on: Mon, 24 February 2014, 17:34:05 »
Are you plugged into the usb port on the motherboard or into a usb port on the pc case? Some of the aftermarket pc cases have sketchy usb ports that will cause the same problem.
Offline uhlsla
« Reply #4 on: Mon, 24 February 2014, 17:41:23 »
Motherboard. The short seems to be just as the cable comes out of the keyboard
Offline digi
  • elite af tbh
« Reply #5 on: Mon, 24 February 2014, 18:15:15 »
Open it and solder in a replacement USB cable.
Offline uhlsla
« Reply #6 on: Mon, 24 February 2014, 19:09:36 »
Nice idea but I don't have a soldering iron and I'm not any good at it. :)
Offline Pacifist
  • on hiatus
« Reply #7 on: Mon, 24 February 2014, 19:12:17 »
What country are you in? Pexon in the UK sells filco cables that look awesome and will fix your problems
Offline t2russo
« Reply #8 on: Mon, 24 February 2014, 19:38:45 »
Don't have to solder.  Filcos have a plug on the PCB for the cable.  Ask any of the custom cable guys on this forum for a cable and specify it's for a Filco.  Pop the case open, remove the old cable, plug in the new one.  Resume part in glorious Filco master-race (I've got three and have swapped cables on two).
Offline uhlsla
« Reply #9 on: Mon, 24 February 2014, 19:50:30 »
USA
Offline uhlsla
« Reply #10 on: Mon, 24 February 2014, 19:54:44 »
T2 would that be in the "making stuff together" part of the forum where I can ask to  get a custom cable made?
Offline t2russo
« Reply #11 on: Mon, 24 February 2014, 19:55:12 »
D-Squad.  My Filco is a Mimic Cable.
http://www.mimic-cables.com/products/custom-usb-cable
Offline uhlsla
« Reply #12 on: Mon, 24 February 2014, 20:02:59 »
Thanks T2! I'll order one.
Offline Dreamre
    • kbdlife
« Reply #13 on: Mon, 24 February 2014, 20:59:07 »
Pexon is also good too! He has a strain relief for the Filco cables.
http://www.pexonpcs.co.uk/
