Author Topic: LYNK 901022-50 122 Terminal Buckling Springs  (Read 4898 times)
Offline False_Dmitry_II
Offline Pacifist
  • on hiatus
Re: LYNK 901022-50 122 Terminal Buckling Springs
« Reply #1 on: Mon, 10 March 2014, 17:34:58 »
nice for caps, great find!
« Reply #2 on: Mon, 10 March 2014, 17:35:46 »
Buy 1 or 2 or make offer for all.
If there are enough people interested.. do a GB and get them even cheaper. The BIN price is great though.
« Reply #3 on: Mon, 10 March 2014, 18:12:04 »
If anybody buys one and decides to replace the top row function keys, I am interested in the caps.
"Technology can make us forget what we know about life."
- Sherry Turkle
Offline berserkfan
« Reply #4 on: Mon, 10 March 2014, 21:59:32 »
Fohat
Are you needing F1-F24? I'm perfectly happy to buy one and let you have the f1-24; you can always pay/swap for it by sending Dorkvader a mat for his model F projects.  :thumb:
Offline Pacifist
  • on hiatus
« Reply #5 on: Mon, 10 March 2014, 22:00:11 »
btw seller told me bulk discount is $12 if anybody wants to arrange a gb
Offline ebacho
« Reply #6 on: Mon, 10 March 2014, 22:00:40 »
I'm in for one if we do a GB.
Offline berserkfan
« Reply #7 on: Mon, 10 March 2014, 22:43:47 »
What's the point of a groupbuy? You spend more on shipping because the price is already so low.
I'm more concerned about:
1) is it only for LYNK terminals, or is it perfectly compatible with other computers?
2) is it easily moddable on a Soarer, or are there weird complications and scancodes to contend with
3) does it have LED lock lights?
Offline Techno Trousers
  • ʘ_ಠ
« Reply #8 on: Mon, 10 March 2014, 23:15:38 »
I'd be shocked if this is anything other than a straight up rebadged IBM or Lexmark M-122.
Offline ebacho
« Reply #9 on: Mon, 10 March 2014, 23:24:03 »
Point taken.  Interested in these questions too actually (though I'm pretty sure for 3, there are no lock lights.)
Offline wharrislv
« Reply #10 on: Mon, 10 March 2014, 23:37:11 »
Got mine, nice find!
Current daily drivers : HHKB Pro 2, HHKB Lite in a server rack, A few Filco numpads in brown and blue, Pure Pro in Brown with Rainbow PBT, CM Ninja in Brown with white engaved PBTs, two Model Ms 89 and 91 with a few red esc, Ergodox full in clear with blanks, a jdcarpe built 40% awaiting some Round 6 keycaps, and soon a Gon custom.  Hundreds more on site at a mechanical friendly work site where I am the purchaser.  If it exists, I probably have used one!
« Reply #11 on: Tue, 11 March 2014, 01:15:48 »
I actually had to ask for a pic of a switch, that's why there's one up now.
Let us know if it's AT or XT or what when you get it.
Offline dgreekstallion
  • B.S. Fiend
« Reply #12 on: Tue, 11 March 2014, 01:22:26 »
I just bought one. I'll let you guys know how it is when it gets here.
Recent keyboard fanatic.
Model F-122 convert.
Offline Pacifist
  • on hiatus
« Reply #13 on: Tue, 11 March 2014, 01:24:35 »
I hope these fit in the M122 case. I'll get two once other people confirm the quality, and hopefully I'll have some sweet boards to use
« Reply #14 on: Tue, 11 March 2014, 01:43:39 »
Are these bigger than that or something?
Offline berserkfan
« Reply #15 on: Tue, 11 March 2014, 02:50:37 »
Pacifist, I strongly suggest you look at the casing carefully. There are a lot of nearly-similar casings that aren't actually the same measurements. I have several M122s (some by IBM, some Lexmark) and their casings aren't the same. I haven't tried to see if the internals will fit though.
« Reply #16 on: Tue, 11 March 2014, 07:42:48 »
Since Lexmark bought the IBM factory and equipment, there is really no doubt.
However, there are multiple generations of M-122 cases and these are almost certain to be last-generation.
- Sherry Turkle
« Reply #17 on: Sun, 23 March 2014, 01:57:46 »
So has anyone run theirs yet?
Offline wharrislv
« Reply #18 on: Sun, 23 March 2014, 17:22:10 »
I got mine on Friday at my office and didn't have my DIN to usb thing with me, so I haven't used it yet, but the board I got was very NIB, in great shape, and certainly a M122 copy.  Once I get it plugged in, I'll let everyone know if it is working OK or not.  For $25  its really a great deal.  I'd pay that much for NIB keycaps anyways, to get a complete KB with it is a really great deal.
Offline Pacifist
  • on hiatus
« Reply #19 on: Sun, 23 March 2014, 17:23:35 »
I  don't think your din to usb thing will work. This is a terminal board, and I'm sure your converter is AT to USB
« Reply #20 on: Sun, 23 March 2014, 17:44:12 »
There's a good chance that it'll work. I believe these are terminal emulator keyboards, so it's a decent bet that an AT to PS/2 passive adapter followed by an active PS/2 to USB adapter will work right away.
Offline wharrislv
« Reply #21 on: Mon, 24 March 2014, 02:19:05 »
Yeah that is the trick from my experience is the active part, but we shall see tomorrow!
Offline wharrislv
« Reply #22 on: Mon, 24 March 2014, 12:35:09 »
So it does NOT work with a standard DIN to PS2 passive and then a PS2 to USB active converter.  Might need a soarer to make it happen...
  • B.S. Fiend
« Reply #23 on: Mon, 24 March 2014, 13:55:09 »
Results?
Offline wharrislv
« Reply #24 on: Thu, 27 March 2014, 20:53:30 »
Results?
Did not work with a "normal" active converter.  I'm guessing it will require a hagstroms or soarers converter.
Offline Pacifist
  • on hiatus
« Reply #25 on: Thu, 27 March 2014, 20:56:55 »
I will buy two once I get more cash. I have an extra teensy which I will use to convert it.
