Author Topic: Steam + Controller  (Read 1878 times)
Offline yester64
Steam + Controller
« on: Tue, 11 March 2014, 21:11:49 »
Hi, i wonder if i can use Steam Big Picture with the following.
My graphics card has an DVI, SVGA output. In theory i could convert it to HDMI. The other thing is the controller. Will the Xbox controller work with the Logitech unified wireless adapter? I have one that i am using with my mouse currently.
Thanks for any input. I do like to play Skyrim over the TV if possible. :)
Rosewill RK-9000BR (trashed)
WASD V1 Keyboard Cherry Blue w/40A Hardness O-Rings
Steelseries 6GV2 Red Cherry Switches
Offline vun
  • Just one more thing
Re: Steam + Controller
« Reply #1 on: Tue, 11 March 2014, 21:34:14 »
Don't think it'll work with the logitech adapter, but there are plenty of usb wireless receivers for the 360 controllers, finding an official windows one isn't too easy these days but there are plenty of third party ones.
All you need then is a DVI to HDMI adapter, those should be very common and easy to get.
Offline yester64
« Reply #2 on: Tue, 11 March 2014, 22:18:30 »
sounds great. I will look for that item.
