Author Topic: Cherry top removal tool  (Read 5390 times)
Offline zeroni13
« on: Wed, 12 March 2014, 16:56:25 »
I really want some dedicated tool for taking cherry MX switches apart. Does a tool like that even exist? Right now I'm using this tool which I made myself with the help of this guide here: http://www.kbdmania.net/xe/tipandtech/3520312 they work well, but I find them very fragile and they don't fit to well in the holes on the switch.
If you know of some better tool or an easy alternative way to remove the top of the switches please enlighten me!
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline zeroni13
Re: Cherry top removal tool
« Reply #1 on: Thu, 13 March 2014, 02:14:44 »
Nobody knows? There has to be a better way.
Offline tbc
« Reply #2 on: Thu, 13 March 2014, 02:20:49 »
the beast switch tool
Offline remdell
« Reply #3 on: Thu, 13 March 2014, 02:33:57 »
Angled tweezers can work too.  You can use two angled tweezers on both ends of the switch, or unlock one side of the switch, hold that opening, and then unlock the other side with the same tweezer.
This video demonstrates it with one tweezer:
« Last Edit: Thu, 13 March 2014, 09:54:25 by remdell »
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
« Reply #4 on: Thu, 13 March 2014, 06:43:45 »
« Reply #5 on: Thu, 13 March 2014, 09:06:38 »
Maybe it was my tool, but I found that the binder clip switch tool worked way better than the_beast switch tool I bought a while back.  I sold it because I wasn't all that happy with it.  I may have just got one that didn't have the right angle on it.  I know that that was an issue with one production run of them.
« Last Edit: Thu, 13 March 2014, 09:12:18 by nubbinator »
Offline zeroni13
« Reply #6 on: Thu, 13 March 2014, 16:49:07 »
^^ this
Guessing that was in a GB, is it still available?
Offline Pacifist
  • on hiatus
« Reply #7 on: Thu, 13 March 2014, 16:54:09 »
^^ this
ti is coming soon
otherwise its hard to find--REALLY HARD TO FIND
Offline zeroni13
« Reply #8 on: Fri, 14 March 2014, 03:55:26 »
Offline Zeal
    • Zeal Generation Inc.
« Reply #9 on: Fri, 14 March 2014, 04:08:05 »
ti is coming soon
What do you mean?
He either meant "it is coming soon" or Titanium (switch tools) are coming soon.   :p
The original switch tools were made of stainless steel, but this time it'll be made out of Titanium!  :eek:
Offline spolia optima
« Reply #10 on: Sat, 15 March 2014, 19:03:45 »
I use a 2-prong pickle fork with the tips bent slightly
keyboards!
Offline Pacifist
  • on hiatus
« Reply #11 on: Sat, 15 March 2014, 19:38:08 »
Offline jacobolus
« Reply #12 on: Sun, 16 March 2014, 00:34:17 »
Two properly bent paperclips works just fine.
« Reply #13 on: Sun, 16 March 2014, 15:54:30 »
Do you have an example?
Offline BlueBär
« Reply #15 on: Sun, 16 March 2014, 16:00:23 »
