Author Topic: What is that IBM Model F Connector?  (Read 3233 times)
Offline kennyk64
« on: Thu, 13 March 2014, 10:17:41 »
Hello fellow Ghers, I came across this keyboard on google and does anyone here knows what type of connector is that?
Poker II  Shine II  Realforce 87u
Offline blackbox
Re: What is that IBM Model F Connector?
« Reply #1 on: Thu, 13 March 2014, 17:26:24 »
Hello. Acording to the d-subminiture standard that should be a da-xx (xx is a number). You can find more information about dsubminiature here:
http://en.wikipedia.org/wiki/D-subminiature
Acording to the thread below it is an da-15 connector.
http://geekhack.org/index.php?topic=12591.0
To find out what connector it is simply count the number of pins in the contact and replace xx with the number.
example:
if it is 15 pins
da-xx is da-15
The LAN table!
Offline Parak
« Reply #2 on: Thu, 13 March 2014, 17:33:14 »
Yep, DA-15. Specifics:
Offline kennyk64
« Reply #3 on: Thu, 13 March 2014, 20:43:48 »
Thanks for the info guys! Will start to look around for more info. Cheers!  ;D
