Author Topic: Rosewill RK-9000BR Mini USB Repair  (Read 2701 times)
Offline Snowmill
« on: Mon, 17 March 2014, 23:47:49 »
I bought a Rosewill RK-9000BR about 2 years ago, the mini USB connector on the KB has recently become a problem.   I assume I purchased one of the variants with the 'bad USB connector' as I have attempted to re-solder the mini USB connector to the board but the pins are actually too short for the solder to get a solid grip and soon after become loose again.
I read elsewhere on the forum that gluing the sides of the USB connector with gorilla glue may solve the problem.  I'm looking for opinions on this and if it's something that will work long term or should I just cut my loses here and buy a newer/better KB?
I also tried securely fastening the mini USB cable to the keyboard as shown in this pic but it hasn't helped that much as there's still some movement and sway: http://i.imgur.com/ITMIjnN.jpg
As I've also been quite happy with the RK-9000BR up until now I haven't invested any time in researching other / better KB's, if anybody has used one these KB's and has a suggestion for a better replacement please let me know and I'll look into it.
Offline laffindude
Re: Rosewill RK-9000BR Mini USB Repair
« Reply #1 on: Tue, 18 March 2014, 01:33:13 »
If it were my board, I'd drill 2 holes near the mini USB connector and zip tie it down.
Offline blackbox
« Reply #2 on: Tue, 18 March 2014, 05:10:53 »
Just buy a new miniusb connector and solder it on.
The LAN table!
Offline zeroni13
« Reply #3 on: Tue, 18 March 2014, 05:11:12 »
If the pins on the connector is too short to solder properly I would just get a replacement connector, de-solder the old one and solder on the new USB connector.
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline Snowmill
« Reply #4 on: Mon, 24 March 2014, 13:09:41 »
Do you have any idea where I could buy a mini usb connector in Canada?
« Reply #5 on: Mon, 24 March 2014, 13:42:31 »
One thing about the OP that immediately caught my attention was the solder not getting "a good grip".  When it involves electronics novices, this almost always means improper soldering techniques.   Usually it's insufficient heat (cold solder joints) but sometimes also too much or too little solder.  I can't see the images from here, but it's something to consider.
Offline blackbox
The LAN table!
