Author Topic: non programable 60% keyboard?  (Read 6690 times)
Offline Jixr
« on: Wed, 19 March 2014, 21:50:35 »
so i have an odd search.
for power draw reasons a poker 2 wont work, and anything backlit wont work either.
I'm looking for a 60% keyboard that is NON programmable, basically plug in play, no onboard storage, etc.
anything out there?
« Last Edit: Wed, 19 March 2014, 21:54:04 by Jixr »
Offline Pacifist
  • on hiatus
Re: non customizable 60% keyboard?
« Reply #1 on: Wed, 19 March 2014, 21:53:03 »
poker x?
ducky mini?
Offline Jixr
Re: non programable 60% keyboard?
« Reply #2 on: Wed, 19 March 2014, 21:55:18 »
poker X sounds good, does it not have any programable features?
Offline Pacifist
  • on hiatus
« Reply #3 on: Wed, 19 March 2014, 21:56:27 »
non programable but there is a built in fn layer
Offline Jixr
« Reply #4 on: Wed, 19 March 2014, 22:00:25 »
that may work...
Basically, I want a keyboard for my ipad, and currently have a poker2, but its power draw is too much, so I have to use a little trick by daisy chaining it through a usb hub to get it to work, and would much rather have a straight plug-n-play if possilbe.
( A quckfire rapid and xt both work with their Fn layers, so it should be fine )
Any idea where to buy one?
Offline Pacifist
  • on hiatus
« Reply #5 on: Wed, 19 March 2014, 22:02:16 »
that may work...
poker x is discontinued but you can look for them on classifieds-one of them just sold today
Offline ideus
  • Björkö.
« Reply #6 on: Wed, 19 March 2014, 22:04:59 »
The classifieds seems to be the best place to get one. You may try ebay also, and DT.
Offline Pacifist
  • on hiatus
« Reply #7 on: Wed, 19 March 2014, 22:05:41 »
ebay won't have them, but DT may. DT is more focused in europe so plan accordingly
Offline Jixr
« Reply #8 on: Wed, 19 March 2014, 22:07:09 »
any idea how much I could expect to pay for one? if they are collectable or are crazy money then I won't bother.
also, anyone know if they are plate mounted or have LED sockets?
Offline ideus
  • Björkö.
« Reply #9 on: Wed, 19 March 2014, 22:07:36 »
I got my Poker X from ebay, that is why I pointed it.
Offline Pacifist
  • on hiatus
« Reply #10 on: Wed, 19 March 2014, 22:09:01 »
When was that and was it from a major seller with 5+ in stock or some random person selling theirs?
PCB mounted, I do belive you can solder in LEDs
I'm not exactly sure the price, but its not that bad
Offline Jixr
« Reply #11 on: Wed, 19 March 2014, 22:13:22 »
just crawled ebay, didn't find anything.
But in theory, I should be able to add a plate and a case later on.
if I can get a poky x for under $100 i'll be happy.
Offline ideus
  • Björkö.
« Reply #12 on: Wed, 19 March 2014, 22:24:01 »
I got my Poker from an individual not from a vendor, and it was last year.
Offline Jixr
« Reply #13 on: Wed, 19 March 2014, 22:26:58 »
I have a poker 2 with greens currently, and since I don't program anything into it, its really tempting to get an X, and basically port my green switches, LED's, plate, case, etc onto the X PCB.
Offline ideus
  • Björkö.
« Reply #14 on: Wed, 19 March 2014, 22:29:06 »
I prefer the arrows option of the Poker X over the one in the Poker II. Of course you can replicate it somehow with the PN layer.
Offline jacobolus
« Reply #15 on: Wed, 19 March 2014, 23:07:29 »
What if you just get some kind of battery pack to mount inside your existing keyboard?
Offline SonOfSonOfSpock
« Reply #16 on: Wed, 19 March 2014, 23:44:39 »
Leopold FCC0 and HHKB are both 60% and non- programmable. Both are in stock at elitekeyboards.com.
« Reply #17 on: Thu, 20 March 2014, 06:44:10 »
The HHKB Pro 2 has that USB hub which I think may cause issue with power draw.
Offline BlueBär
« Reply #18 on: Thu, 20 March 2014, 07:18:23 »
What I don't get is why you don't want it to be programmable then?
Also why do you want to port your LEDs into a Poker X if they caused the issue before? I think there is also some PCB tinkering involved with getting a Poker X all backlit.
Offline Jixr
« Reply #19 on: Thu, 20 March 2014, 08:25:17 »
because the onboard memory is the power hog. And I never use the program settings on my current poker anyway.
And as far as wiring in a battery to the case, Basically I would need to wire in and hide a PCB off a usb hub into the case, I've tried it before and coulnd't quite figure out how to wire it in.
Offline BlueBär
« Reply #20 on: Thu, 20 March 2014, 08:51:15 »
Are you sure about that? Should be just some flash memory, does that really draw that much power? Weird.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #21 on: Thu, 20 March 2014, 09:09:32 »
FWIW, I've used both the Poker X and the Pure on my iPad without issue. Neither of those are programmable.
I have a couple of Pure keyboards without cases if you're just looking for the PCB and switches. PM me if you're interested.
Offline mougrim
« Reply #22 on: Thu, 20 March 2014, 09:39:07 »
What the hell is DT?
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline BlueBär
« Reply #23 on: Thu, 20 March 2014, 09:41:50 »
Deskthority.net, a keyboard forum similar to Geekhack, but a bit more Europe focused. We have a Glossary btw :thumb:
Offline Grendel
« Reply #24 on: Thu, 20 March 2014, 13:04:23 »
I doubt that. The Pure Pro eg. uses an Atmel serial EEPROM, these take around 1mA max. during normal operation and 3mA max. during write. Hardly a "power hog".
- I'm game !
Offline Jixr
« Reply #25 on: Thu, 20 March 2014, 13:38:00 »
well, i know my non programable keyboards work fine, but the pokey 2 does not, unless the pcb is just designed to draw more power than the ones on my other mechs.
Offline mashby
    • Mashby
« Reply #26 on: Thu, 20 March 2014, 13:41:30 »
You should just mail me your Poker 2. You know, for testing! Yeah, that's it, for testing.  ;)
Offline BlueBär
« Reply #27 on: Thu, 20 March 2014, 15:21:44 »
So what about the LEDs?
Offline Jixr
« Reply #28 on: Thu, 20 March 2014, 15:48:15 »
none of my others have led's aside from the caps lock and such. ( which work )
Offline BlueBär
« Reply #29 on: Thu, 20 March 2014, 16:24:18 »
So you think that rather than full Backlighting the flash memory is the cause of the power draw? That is some flawed logic.
