Author Topic: Been Given a couple of free keyboards....but they're domes :(  (Read 2172 times)
Offline GiraffePencils
« on: Thu, 20 March 2014, 05:12:06 »
So a friend at work told me he had a couple of old keyboards I could have, he was vague on the age but a part of me hoped for some mechanical keys...
Alas they appear to be domes :(
Is there anything to be done with them?
They look fairly old. (a subjective view as I myself am probably younger than them lol)
Re: Been Given a couple of free keyboards....but they're domes :(
« Reply #1 on: Thu, 20 March 2014, 06:41:26 »
Pictures would go a long way otherwise we have no idea what you have :D
« Reply #2 on: Thu, 20 March 2014, 06:41:47 »
Well, what are they?
Even among rubber dome keyboards, some are much better than others.
- D Trump 2026-10-24
« Reply #3 on: Thu, 20 March 2014, 06:56:45 »
ok sorry, "Old keyboard" is fairly vague :))
I'm at work, So give me ~40 mins till lunch and I'll get some pictures.
« Reply #4 on: Thu, 20 March 2014, 08:10:33 »
So, got some pictures, Had to charge my phone so I'm a bit later than I said
Offline mougrim
« Reply #5 on: Thu, 20 March 2014, 09:41:38 »
Nice caps on HP one. Might be doubleshot. If that true - it might be worth something, especially if they are removable and have compatible with one of mechanical switches mount.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline blackbox
« Reply #6 on: Thu, 20 March 2014, 10:00:58 »
Take out one of the keycaps an take a photo of the top and bottom. Then it is easier to tell what type of keycap it is.
The LAN table!
« Reply #7 on: Thu, 20 March 2014, 10:48:22 »
Keycap pictures:
Offline mougrim
« Reply #8 on: Thu, 20 March 2014, 11:07:27 »
I think, pad printed with non-standard mount.
Looks like Topre mount, though. But I think it not the one.
« Last Edit: Thu, 20 March 2014, 11:09:41 by mougrim »
« Reply #9 on: Thu, 20 March 2014, 11:13:11 »
Picture of the cap hole:
Incase that matters
Offline mougrim
« Reply #10 on: Thu, 20 March 2014, 11:23:27 »
Rubber domed. But pretty nice for a rubber domed. I'd say it worth some bucks cleaned. Not many, but around 20. You can search ebay for past listings.
« Reply #11 on: Fri, 21 March 2014, 06:04:01 »
Oh well, Thanks for the help
Might give it a clean, maybe make it USB for the fun of it.
