Author Topic: PS2 PCI Cards - why not add one?  (Read 7375 times)
Offline nowsharing
  • Swoop
« on: Mon, 30 March 2009, 22:06:12 »
Hi, I'm a casual lurker of your board and am finally making my first post.
I must be searching poorly, because I can't find any discussion of add-on desktop ps2 cards. Is there any reason not to choose a ps2 pci card instead of a usb adaptor? It just seems right to go native...unless these cards use some kind of ps2 to usb process within them anyways. Here is one on ebay that I'm considering. I see that the syba brand ps2 cards have horrid reviews at newegg, so I'm avoiding those. Anyone have experience with this sort of thing?
Cheers
Offline Hak Foo
  • Make America Clicky Again!
« Reply #1 on: Mon, 30 March 2009, 23:28:53 »
Are they really PS/2 ports, or PS/2 to USB under the hood?
IIRC, the keyboard and mouse reside on specific interrupts, not necessarily supplied by the PCI bus.
Overton130, Box Pale Blues.
Offline cchan
« Reply #2 on: Tue, 31 March 2009, 06:27:44 »
Quote from: The listing
The PS/2 Ports are compliant with USB HID specification and will work with any PS/2 keyboard or PS/2 mouse.
Seems like they use an internal ps/2 -> usb converter chip.
HP Envy17: Core i7-2760QM, 8GB DDR3, 128GB Crucial m4 + 750GB Hitachi, Windows 7 Home Premium x64, Cherry ML4100, Logitech M500, HP zr22w
IBM Thinkpad X60: Core Duo T2400, 2GB DDR2, 128GB Samsung 830, Xubuntu 12.04 x86, Cherry ML4100, Logitech M205, HP zr22w
Raspberry Pi Model B: BCM2835, 0.25GB DDR2, 8GB Samsung SD card, Raspbian Wheezy, human interaction devices as above
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Tue, 31 March 2009, 07:20:14 »
I think your best bet is going to be to replace the motherboard with one that has PS/2 connectors for the keyboard and mouse.
Offline FKSSR
« Reply #4 on: Tue, 31 March 2009, 08:07:53 »
That card may not be a bad idea if you are using a PS/2 keyboard only on one computer (don't need to transport it to another computer that doesn't have PS/2), especially since it looks pretty cheap.
If you end up getting it, let us know how it turns out, especially if you have any problems with any keyboards.
Add me on Steam | Twitter
Offline bhtooefr
    • bhtooefr.org
« Reply #5 on: Tue, 31 March 2009, 08:44:49 »
It's just a PS/2 to USB to PCI adapter...
Offline nowsharing
  • Swoop
« Reply #6 on: Thu, 02 April 2009, 21:50:25 »
Thanks for the insight everyone, it saved me some time and a little cash.
I just read a writeup at ClickyKeyboards on this issue and thought that I should give the definitive end to this question (you can't add native ps2 using these cards), thus killing the hopes of anyone hoping to find a way to add native ps2 to a non-ps2 mobo.
from clickykeyboards.com:
Question: I am very familar with ’puters and am good with a screwdriver and I know how to open my computer. Why can’t I buy an expansion card with a ps/2 port that fits into a PCI slot. I have seen these before on my computers at work and they must be readily available.
A. As a corporate IT admin and systems engineer in real-life, I have seen Dell computers with ps/2 ports on the back of computers where the PCI slot covers are. However, this specialized part sold by Dell (part# F3636) was only intended to be used with certain Dell Optiplex computers. This part does not actually plug into any PCI slots of the motherboard, but insteads uses a 24-pin ribbon cable to connect directly to a special connector on certain Dell Optiplex motherboards.
The keyboard interface is an elementary low-level device and it needs to be initalized very early during the boot process. Any true PC hardware geek with real-world experience knows that the PCI bus is not setup and cannot be used to capture the type of direct, low-level I/O signals between the keyboard and computer.
It's humbling, but there you have it.
The best choice is a ps2 to usb converter (as opposed to just an adapter), there's great info on that here. This is probably just a big DUH! for most of you.
