Author Topic: Vintage Cherry MX Black Sources  (Read 10536 times)
Offline PointyFox
« on: Thu, 27 March 2014, 00:20:05 »
What are some sources for vintage Cherry MX Blacks?  I mean the really smooth kind.
Re: Vintage Cherry MX Black Sources
« Reply #1 on: Thu, 27 March 2014, 00:24:18 »
Old (80s) Cherry keyboards or WYSE terminal keyboards. But since Soarer made his WYSE converter available, they are useful for more than just harvesting switches and keycaps now.
Offline PointyFox
« Reply #2 on: Thu, 27 March 2014, 00:34:00 »
I've had 2 Cherry keyboards with MX Black and both had the gritty mx black switches.  Not sure the dates on them, but they were either 80s or early 90s.
Offline Pacifist
  • on hiatus
« Reply #3 on: Thu, 27 March 2014, 00:35:59 »
They need to be really old, early 80's prefered
Offline eth0s
  • Peace & Love
« Reply #4 on: Thu, 27 March 2014, 00:44:52 »
Hey, I've got 7 WYSE terminal keyboards from late '80's or early '90's, with buttery smooth MX blacks.
The keyboards came from a law firm that switched to the newer WYSE rubber dome keyboards (fools).  Anyway, I think those guys used to smoke in the office, cuz, the keyboards are pretty yellowed.  But with Soarer's controller and a bath in the old retr0brite solution, they might be pretty sweet keyboards again.  Otherwise they are good for harvesting 105 vintage MX blacks.
Note:  they also come with the original WYSE thin doubleshots.  And the MX black switches are plate mounted, requiring you to desolder them.
PM me if you want one.  Shipping is going to cost a few $'s, cuz they weigh about 3 lbs each.
« Reply #5 on: Thu, 27 March 2014, 00:46:06 »
There's no guarantee you'll get the "vintage" blacks.  I've had boards from the early 80s without them and boards from the late 80s/early 90s that had them and had boards with a mix of switches.  In my experience, there's no guarantee that you'll find "vintage" blacks.  Of course, I'm also of the opinion that vintage blacks are just broken in blacks since I've had bad "vintage" blacks and fantastic old blacks and new blacks (I've found at least three different switch top styles on black switches).   Cap thickness with Wyse isn't really an indication either.
Offline eth0s
  • Peace & Love
« Reply #6 on: Thu, 27 March 2014, 00:49:51 »
+1 to this ^.  I think the buttery smooth vintage blacks are really the result of heavy use.  All the rough parts get worn super smooth.
Offline Pacifist
  • on hiatus
« Reply #7 on: Thu, 27 March 2014, 00:51:48 »
We need to invent a device that actuates switches over and over to make them smooth
« Reply #8 on: Thu, 27 March 2014, 00:54:21 »
I have a Link terminal keyboard from circa 1988.  It has MX blacks, and they are as smooth as!
But the Cherry logo on the keycaps is the larger one from the newer black switches, so I dunno.
« Reply #9 on: Thu, 27 March 2014, 00:57:59 »
I would imagine this would work:
NSFW, but not in any way graphic:
Yeah, that's why I say it's just broken in and well aged switches, not some other magical component.
Offline blackbox
« Reply #10 on: Thu, 27 March 2014, 02:54:05 »
Some maltrons have vintage black
The LAN table!
Offline PointyFox
« Reply #11 on: Thu, 27 March 2014, 04:12:12 »
I doubt it because I've had boards with all smooth vintage blacks, and commonly pressed keys like 'E' felt the same as keys like "pause/break".
Offline kaz
« Reply #12 on: Thu, 27 March 2014, 06:23:04 »
Could vintage blacks just have a slightly weaker spring? Someone needs to disassemble the two and figure it out.
Cherry G80-11800 (Workhorse) | Cherry G80-11900 | \'93 IBM Model M | Apple M0116
Offline mougrim
« Reply #13 on: Thu, 27 March 2014, 06:53:44 »
Kinda. I have old WYSE terminal board, but I ain't decided what to do with it yet - either sell or try to convert. But it feel really, really smooth - not really what I look for in switches, but nice...
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #14 on: Thu, 27 March 2014, 07:59:35 »
The problem I see with many of the terminal boards is often times I suspect they had been refurbished over the years... switches replaced and so on. It's not break in at all either... as I have NIB vintage G80 models with super smooth vintage blacks. In case of Cherry it's all about getting boards made before 1991, but before 1988 is even better. G80-1000HA* models would be an excellent chance, and any G80-0*** MX model pretty much a guarantee even though I feel dismantling them is a terrible thing to do. Other boards like those made by Dah Yang (Unitek, Magitronic, Dytcom, etc) most often have blacks, but you may find blues as well. Very old Qtronix may be an option if you see them for cheap... but again they could have blues or high chance some kind of MX clones...
Or if you want something a little different, hunt down one of the old TA typewriters that have the MX linear white/clear switches. Personally these are my favorites, but I haven't had a lot of luck getting more of them to fill up full keyboards larger than 60%.
Offline BlueBär
« Reply #15 on: Thu, 27 March 2014, 08:02:09 »
They sometimes have a slightly weaker spring, but that is because of use and age. The spring does not affect the smoothness.
Offline khaangaaroo
« Reply #16 on: Thu, 27 March 2014, 11:34:29 »
^This is truth.
People need to stop spreading misinformation that vintage blacks are just heavily worn blacks. Very worn modern blacks, even lubed, will still never be as smooth as NIB vintage blacks. Get your hands on one of each and compare side by side before you start saying things.
« Reply #17 on: Thu, 27 March 2014, 12:50:36 »
If you want people to believe you, the vintage Black proselytes, you should organize a blind test between new "vintage" Blacks, used "vintage" Blacks, used old Blacks, new new Blacks, and used new Blacks.  If you want people to believe your claims, you need to prove them instead of shifting the onus to the doubters.  I speak from my own experience with them and Cherry's statement about them, but I'm willing to change my beliefs if there is sufficient evidence.
« Reply #18 on: Thu, 27 March 2014, 13:09:05 »
I wonder if anyone ever did any of the 'testing' that was talked about a few months ago. I was hoping we would get some answers from that.
Offline BlueBär
« Reply #19 on: Thu, 27 March 2014, 13:10:55 »
I let a friend of mine test Vintage Blacks and normal Blacks and asked if he felt a difference. He did and described the normal Blacks as a bit more scratchy.
Offline mougrim
« Reply #20 on: Thu, 27 March 2014, 13:16:00 »
Hmmm.... not purely blind testing, but close enough :)
Offline BlueBär
« Reply #21 on: Thu, 27 March 2014, 13:18:20 »
Well they look the same if you don't look very close and I had keycaps from the same set in the same profile on them so I would call that test fair.
Offline davkol
  •  Post Editing Timeout
« Reply #22 on: Thu, 27 March 2014, 13:24:13 »
  • randomly mix vintage and modern switches on a keyboard
  • type on the keyboard
  • rate smoothness of each key
  • remove keycaps and find out, which switches are which
Offline stancato9
« Reply #23 on: Thu, 27 March 2014, 13:30:10 »
I've been looking for these for quite some time now. If anyone has a source, or wants to sell me some for a fair price I would appreciate it. :)
Poker 2 - MX Red
Offline BlueBär
« Reply #24 on: Thu, 27 March 2014, 13:30:51 »
I can send you a few if you want?
Offline khaangaaroo
« Reply #25 on: Thu, 27 March 2014, 13:37:21 »
I've done that before, shipped a single new vintage switch along with a single new modern switch from wasdkeyboards to members here so just to convince them :P
For me, the thing that points to vintage blacks not being smooth by heavy use is that all the switches feel the same across the entire board for every board I've acquired with vintage switches.
Offline davkol
« Reply #26 on: Thu, 27 March 2014, 13:45:35 »
I've already bought a set from kint, but it'd be nice to have more data in the long run. Too bad I need to focus on different stuff these days.
Anyway, I've conducted an experiment similar to yours, will post results later, if I don't forget about it (as usual).
