Author Topic: Trying to find out the switch type for me...using blues now, want a change  (Read 3149 times)
Offline Xarmydis
I love the crisp feeling of blues, oh so much, but these are too gosh darned noisy for me. Browns are softer, yes, and are still tactile, but they just don't find as crisp as blues to me, and I'm looking to go heavier.
So, pretty much, I'm looking for crisp, tactile, soft, and at least the weight of blues, but harder definitely preferred.
I was looking at whites/clears, is there anything else I should be looking at? How soft are those really? These blues are so freaking loud. Like, obnoxiously so.
Offline blackbox
What about a brown with a heavier spring?
The LAN table!
Offline RESPRiT
  • HHKB = ❤
Maybe ergo-clears?
Offline tbc
you're looking for clears or 55g topre.
Offline BlueBär
I would suggest Clears as well. They are nicely tactile and not as loud as Blues, and also heavier, so pretty much everything you want. Whites is another option but they can be tricky (because sometimes their click is uneven) and they are fairly rare.
Offline QuadGMoto
It definitely sounds like you're describing clears. They're roughly 65g compared to the blues' and browns' 55g.
Offline BlueBär
I'm not sure where you're getting those numbers from, but the don't match up with any of mine...
Offline QuadGMoto
They're based on doing the nickel test, which is admittedly crude.
Offline BlueBär
Here are some exact measurements: http://geekhack.org/index.php?topic=46449.0
The nickel test should not be used if you have more exact measurements.
Offline QuadGMoto
Ummmm… All I see there is measurement of the bare springs. The bumps in the stem pressing against the leaf spring to produce the tactile feel necessarily changes the force needed.
I also noticed that in that chart, the middle of the light (blue, brown) spring is 50g and the clear spring is 65g, right in line with what I said.
That said, I would like to see that level of measurement of full switch assemblies. I even looked into what it would take to get force plus distance measurements, but I don't have the 5 to 7 thousand dollars to buy the kind of equipment needed to do it right, especially just for testing a few switches.  :o I've been trying to figure out if anyone I know already has the right gear.
Offline morpheus
Matias Quiet Pro?
Drawback is you can't customize it as readily as Cherry MX.
Offline QuadGMoto
Matias Quiet Pro?
Good point. Matias is selling their switches individually (though they're not pin compatible with the MX series) and has openly talked about selling custom key caps for them. (See their forum.) They've also announced an ergonomic keyboard too.
Offline BlueBär
Only for activation force. The bottom out force will stay the same.
You were 5g off, but yes they were close. However activation forces are documented, see below, therefore the nickel tests are really not needed.
Cherry has the activation forces well documented, you can find them in the Deskthority wiki, for example here: http://deskthority.net/wiki/Cherry_MX_Blue
Offline QuadGMoto
True, but those are only for stock Cherry switches. It would be nice to know what the curves are for modified switches, as well as different designs, such as the Alps in my old AEK. And of course, for the best head-to-head comparison, all the switches should be tested under the same conditions to eliminate variables, such as any potential differences between Cherry's procedure and the one used for testing other switches. And let's not forget the theories about variations over Cherry's production history.
Offline BlueBär
Jesus that would be a lot of measuring :eek:
I think for heavier springs you could just scale the graphs accordingly. On the other hand, I don't think numbers really express how a switch feels after all ;)
Offline johndavis33
Clears aren't very "crisp", otherwise I'd say they're the best.
Whites seem to be a good idea. They're stiffer than blues, more tactile, IMO more crisp, and they're definately quiter.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
