Author Topic: EneBRICK HHKB Edition - HHKB Bluetooth Connectivity  (Read 7221 times)
Offline RESPRiT
  • HHKB = ❤
« on: Fri, 28 March 2014, 02:00:32 »
Link to the product here: http://www.pfu.fujitsu.com/direct/hhkb/detail_enebrick.html
It seems to act as a device that allows your HHKB to have Bluetooth connectivity, as well as act as a smartphone/tablet stand/charger. The price is around $130, so rather steep, although I don't know of any other solutions for a Bluetooth HHKB.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: EneBRICK HHKB Edition - HHKB Bluetooth Connectivity
« Reply #1 on: Fri, 28 March 2014, 02:20:24 »
Looks pretty cool, its from PFU (HHKB manufacturer) too so it should be fairly decent quality. The price is definitely stee, I'm guessing it has a much larger battery than competing devices though as it seems to be a fair bit larger than the ones I've seen.
Offline atlas3686
  • HHKB Elite
« Reply #2 on: Fri, 28 March 2014, 02:33:54 »
Yes it seems the battery is a big part of it, it will charge devices. Looks great but they don't mention it working with a PC/Mac via bluetooth although I am guessing it would. That price plus shipping and customs though is just too epic.
Offline Belfong
« Reply #3 on: Fri, 28 March 2014, 04:46:31 »
I don't like that I still need to connect to the brick via a cable because if I still need a cable, I might as well connect directly to the PC or the monitor (nowadays, monitors have USB hubs). Of course I can't think of a better design - perhaps something flat in which I can put the HHKB on top of, or perhaps it acts as a wrist rest but is actually the battery.. that, at least, is more practical than this brick.
Offline atlas3686
  • HHKB Elite
« Reply #4 on: Fri, 28 March 2014, 07:07:30 »
I think they specifically targeting mobile devices so a stand made sense but I agree with you.
« Reply #5 on: Fri, 28 March 2014, 07:09:52 »
Something like a flat slicebattery for a laptop would be interesting, if the HHKB case had a slot in the bottom allowing for it to 'dock' then that would bypass having any cables and add some weight!
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
HHKB Introduces EneBRICK
« Reply #6 on: Fri, 28 March 2014, 17:07:51 »
Looks like Fujitsu's answer to making the HHKB a bluetooth keyboard is to add a battery brick to it. They call it the EneBRICK.
I suppose it could be used with any keyboard, but it feels a bit like going around your elbow to get to your butt doesn't it?
Mod Edit: Merged with existing thread
« Last Edit: Fri, 28 March 2014, 17:31:31 by jwaz »
Offline hcry4
  • HHKB Hoarder
Re: HHKB Introduces EneBRICK
« Reply #7 on: Fri, 28 March 2014, 17:27:29 »
Offline Zeal
    • Zeal Generation Inc.
« Reply #8 on: Fri, 28 March 2014, 17:29:50 »
Interesting, but couldn't you just plug a camera to usb adaptor for ipads rather than plugging it into a power bank?
It's still adding bulk for a "wireless" keyboard.  :-X
