Author Topic: Thrift shop finds! Need help identifying.  (Read 4154 times)
Offline metalmatt13
« on: Mon, 31 March 2014, 22:07:47 »
I found these two guys at a used electronic store for $3 each today. The first is a Dell AT101W with black ALPS, while the second is a Packard Bell which I don't know the type of switch.
The PB has a tactile bump and then a click on the release.
Edit: I found a ebay listing of the same board: http://www.ebay.com/itm/Super-Minty-Vintage-Packard-Bell-Keyboard-101-M1US06A-P9-Desktop-PC-Click-1980s-/400635635769
Here is the Dell:
59311-0
And here is some pics of the Packard Bell. If anybody needs a clearer image or a different part I'll take another.
59313-1
59315-2
59317-3
« Last Edit: Mon, 31 March 2014, 22:11:07 by metalmatt13 »
Re: Thrift shop finds! Need help identifying.
« Reply #1 on: Mon, 31 March 2014, 22:35:13 »
Looks a lot like Futaba switches to me
http://deskthority.net/wiki/Futaba_clicky_switch
edit: FCC ID corresponds to Se Jin of South Korea (1988), se jin is a known user of futaba clicky switches.
« Last Edit: Mon, 31 March 2014, 22:37:42 by dorkvader »
Offline metalmatt13
« Reply #2 on: Mon, 31 March 2014, 22:40:50 »
I think I'd have to agree. It does look like the Cherry MX mount variant.
Offline Pacifist
  • on hiatus
« Reply #3 on: Mon, 31 March 2014, 22:44:15 »
once again those stickers with the RGB dots
where do these companies buy them?
« Reply #4 on: Mon, 31 March 2014, 22:44:50 »
I don't think it's cherry MX mount, it looks like the inverse of that. (I was going to say inverse cross, but inverse cross is an SMK switch)
Offline metalmatt13
« Reply #5 on: Mon, 31 March 2014, 22:53:56 »
Wait you're right. I only quickly glanced at it and thought it had a cross.
Offline metalmatt13
« Reply #6 on: Mon, 31 March 2014, 22:56:21 »
Also; I opened it up and the switches were plate mounted if anybody cares to know.
Offline metalmatt13
« Reply #7 on: Wed, 02 April 2014, 01:05:01 »
Oh also, it has the little rubber plug on the back that says "AT Only" next to it, and there are two little switches under it. Never had a board with this, anybody know what it is?
« Reply #8 on: Wed, 02 April 2014, 01:17:29 »
Usually switches like that change it between AT and XT signalling (they use the same connector). I guess they picked AT only for this KB.
Offline jacobolus
« Reply #9 on: Wed, 02 April 2014, 01:59:47 »
This is definitely Futaba clicky switches. Personally I’m not a fan. Those keycaps look double injection molded (albeit shiny) though, so there’s something.
