Author Topic: Poker II or the Ducky Premier  (Read 2010 times)
Offline GiraffePencils
« on: Tue, 01 April 2014, 05:37:03 »
So I was all set in my head to get a Poker II,
it was gonna set me back 90 GBP and I was ok with that, a bit miffed as it's a 60%
Now I can get the Ducky Premier for 99 :O
I type in dvorak, and apart from really liking the neatness of the Poker I'm not attached to 60%.....
So, the decision, Is it a good shout to get it?
It's a good board either way yeah?
Or go all out, get both and use one for work :P
Offline Mooby
  • Funployee
Re: Poker II or the Ducky Premier
« Reply #1 on: Tue, 01 April 2014, 05:40:00 »
I don't think you can go wrong with the Ducky. If you think there's something missing you can still get the Poker afterwards.
May I ask where you'd buy the Premier from?
Offline tbc
« Reply #2 on: Tue, 01 April 2014, 05:44:55 »
premier is the logical way to go.  builtin dvorak; save your time.
« Reply #3 on: Tue, 01 April 2014, 05:46:56 »
Can I link Sites? If not let me know I can remove:
UK:
http://www.overclockers.co.uk/productlist.php?groupid=702&catid=2705&sortby=nameAsc&subid=&mfrid=647
They are owned by the german company caseking, so might hit their shop soon
Can anyone see a problem with re-arranging the Keys?
Doesn't look like there's a legend that would interfere
Offline Mooby
  • Funployee
« Reply #4 on: Tue, 01 April 2014, 06:26:53 »
I'm pretty shure the Ducky has OEM Profile. So you'll get a problem if you move keys to different rows.
Here's some info regarding profiles: http://deskthority.net/wiki/Keyboard_profile
This groupbuy can solve the issue since all the keys there have the same profile and can be swapped around as you like.
http://geekhack.org/index.php?topic=56354.0
Offline Razor Lotus
« Reply #5 on: Tue, 01 April 2014, 10:48:46 »
if you buy from qtan's store i think you can get the poker for 65GBP shipped?
Just that it won't be in UK layout
Offline Mooby
  • Funployee
« Reply #6 on: Tue, 01 April 2014, 11:10:27 »
I just saw the Premier from overclockers is a preorder. You'd have to wait for it anyway.
Offline Linkbane
« Reply #7 on: Tue, 01 April 2014, 16:29:43 »
If you go to Ducky's website, they have a decent list of retailers for every location. I'd recommend the Premier; some of the thickest PBT you can get and excellent quality. As a Dvorak user, however, I recommend you don't switch letters around and just learn to touch type, as it seems everyone else I know do.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #8 on: Wed, 02 April 2014, 03:10:54 »
Yeah, I've decided to just get it, leave it qwerty
Caps are just too good :P
I can touch type, it's just I can't touch type special chars, meh, I'll learn I suppose.
Any link to this 'qtan'?
On another note, I'm gonna buy both :D
Offline epzy
  • HHKB Fiend
  • ded
« Reply #9 on: Wed, 02 April 2014, 05:19:45 »
Keyboardwow.com is his website.
