Author Topic: Convert din to PS2  (Read 2474 times)
Offline da20valve
Convert din to PS2
« on: Tue, 01 April 2014, 06:25:22 »
Can you convert the old type keyboards to USB or PS2 or can only some be converted.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Offline damorgue
    • Personal portfolio
Re: Convert din to PS2
« Reply #2 on: Tue, 01 April 2014, 06:33:16 »
Soarer has made some code available so that you can build a converter out of a teensy controller. It supports a few different protocols and can make them all into USB.
For the record, if you just want to convert it to PS/2 then it is sometimes trivial if it is the same protocol since it is just a differently sized physical connector.
Offline mougrim
« Reply #3 on: Tue, 01 April 2014, 06:50:58 »
If your board AT-compatible, you can just solder an PS2 connector to it or use passive adapter - which is dirty cheap.
Or you can use Soarer's converter to make it usb-compatible.
If it's board with XT-protocol, you NEED Soarer's converter.
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline da20valve
« Reply #4 on: Tue, 01 April 2014, 07:48:29 »
Just realized my mainboard doesn't have PS2, so I will have to go DIN to USB.
« Reply #6 on: Tue, 01 April 2014, 16:26:42 »
Yes, to the extent that I had my old NEC keyboard working well no my Mac.
