Author Topic: Looking for a keyboard with large Alt key  (Read 4945 times)
Offline michael730
« on: Fri, 04 April 2014, 07:43:24 »
i need mehcanical keyboard with very long alt key even better if its as big as shift and cover the windows key like this
                        [Ctrl] [  Alt  ] [      Space      ]
something like this exist?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Looking for a keyboard with large Alt key
« Reply #1 on: Fri, 04 April 2014, 07:45:51 »
Can you be more specific about what you need? Keyboard keycaps are measured in units, where 1u is the width of a normal alpha key. The two standard sizes for Alt are 1.25u ("modern" keyboards) and 1.5u ("vintage" keyboards). If you're looking for a key to fit in a certain spot on your keyboard, you're going to need to be more precise.
Offline michael730
« Reply #2 on: Fri, 04 April 2014, 08:15:19 »
i want to buy a new keyboard and i am using the alt key a lot in games so i want to know if a keyboard exist with longer alt key for example instead of having
Ctrl windows key alt Space i would have it Ctrl then a long alt from ctrl to space keyboard like this exist ?
like this [Ctrl] [    Alt     ]  [        space       ]
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Fri, 04 April 2014, 08:15:38 »
I've only seen such things on some weird old terminal keyboards which aren't likely to be very feasible to use on modern PC without a LOT of work. I think the most easy would be to settle for something like winkeyless Cherry g80-1800 model.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Fri, 04 April 2014, 08:16:03 »
Get this thing, then use some program to switch Ctrl and Alt!
Offline zeroni13
« Reply #5 on: Fri, 04 April 2014, 08:21:27 »
You could make a Phantom keyboard and get a custom plate design made for your purpose. Then you can make almost any layout you want. Still don't know how you would mount the switch for this purpose. Just a thought.
Phantom PCB:
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
