Author Topic: cheap orange Alps  (Read 1489 times)
Offline jacobolus
Re: cheap orange Alps
« Reply #1 on: Mon, 07 April 2014, 06:21:15 »
I was looking at that bottom one the other day. What is the deal with the white/orange stem inserts?
Are you sure that the top one has Alps? Those are some funky keys.
- D Trump 2026-10-24
Offline Ordloh
« Reply #2 on: Mon, 07 April 2014, 07:57:42 »
the keycap stem broke off and is stuck inside the switch. it'll be difficult to get out
« Reply #3 on: Mon, 07 April 2014, 08:25:43 »
Duh! Of course.
Offline jacobolus
« Reply #4 on: Mon, 07 April 2014, 13:49:00 »
There are two types of these IIGS keyboards. This type is PBT caps and orange Alps. The other type is thick double-shot ABS caps and white SMK switches. You can tell it’s the PBT version because the spacebar is still ABS so it yellows, while the other caps don’t.
