Author Topic: 23 G81-8000HPBUS-2  (Read 6160 times)
Offline Pacifist
  • on hiatus
Offline eth0s
  • Peace & Love
Re: 23 G81-8000HPBUS-2
« Reply #1 on: Sun, 13 April 2014, 18:30:20 »
http://www.ebay.com/itm/Cherry-G818000HPBUS2-Black-PS2-keyboard-3track-magnetic-swipe-Lot-of-23-/141255156447
Man, I wanted to find a new one of those for the longest time.  But then I found Topre, and I sort of lost the urge.
FYI:  These keybo's have a nearly Filco compatible Cherry double-shot set on them.  All you need is a center-stemmed Caps Lock.  Or you can do mod on the stepped Caps Lock.
Too bad they look so used and shiny.
Offline Pacifist
  • on hiatus
« Reply #2 on: Sun, 13 April 2014, 18:31:02 »
Man, I wanted to find a new one of those for the longest time.  They have a nearly Filco compatible Cherry double-shot set on them.  All you need is a center-stemmed Caps Lock.  Or you can do mod on the stepped Caps Lock.
also you need new spacebar and bottom row mods
Offline Candyflip
« Reply #3 on: Sun, 13 April 2014, 18:31:24 »
Arent the mods off center stemmed too?
Edit: I thought so  ;D
Offline eth0s
  • Peace & Love
« Reply #4 on: Sun, 13 April 2014, 18:32:57 »
No, all you need is a spacebar (which is super easy to get from SP nowadays).  The bottom row mods should be fully compatible.  They are all 1.25.
Offline Pacifist
  • on hiatus
« Reply #5 on: Sun, 13 April 2014, 18:33:34 »
I own two of these boards for parts. Its off centered
Offline eth0s
  • Peace & Love
« Reply #6 on: Sun, 13 April 2014, 18:33:38 »
Are they off-center?  I thought they were regular.  Oh well, stupid Cherry.
Offline Pacifist
  • on hiatus
« Reply #7 on: Sun, 13 April 2014, 18:34:40 »
yup
off center and pad printed
only for g81 POS boards. Regular g81s are all regular
Offline Candyflip
« Reply #8 on: Sun, 13 April 2014, 18:34:57 »
Yea basically every 81 or MY has off centered mods.
Offline Pacifist
  • on hiatus
« Reply #9 on: Sun, 13 April 2014, 18:36:58 »
wrong: only the POS ones
Offline eth0s
  • Peace & Love
« Reply #10 on: Sun, 13 April 2014, 18:41:53 »
yup
Okai, now I understand.  Only the POS have the off-centered mods.  'Cuz I remember people searching for these a few years back like crazy.  I guess it was the standard G81-8000H-series.  NOT the POS series.  So FYI:  get the non-POS version for a sweet set of cherry double shots.  Otherwise you gotta buy two boards to get one complete set.
« Reply #11 on: Sun, 13 April 2014, 18:43:03 »
G81-3004LANCH isn't POS and it has off centered spacebar and 1.25mods.
Offline Pacifist
  • on hiatus
« Reply #12 on: Sun, 13 April 2014, 18:44:42 »
Thats strange. I remember reading here that it was the less common non POS MY boards that had regular caps. Do you know if the 3004 is the only one or are there more?
« Reply #13 on: Sun, 13 April 2014, 18:46:56 »
Any Cherry G81 board with thick PBT lasered keycaps, and 1.25x mods will have off center 1.25 mods and off center spacebar.
« Reply #14 on: Sun, 13 April 2014, 18:50:59 »
Pic for reference
Offline ebacho
« Reply #15 on: Sun, 13 April 2014, 18:54:51 »
There's also a chance to get the weird MY stabilizers that are molded onto the key itself, which means that even if you have a custom board to use the offset spacebar you're out of luck.
« Reply #16 on: Sun, 13 April 2014, 18:57:02 »
I think that's only found with thin PBT, right?
Offline ebacho
« Reply #17 on: Sun, 13 April 2014, 18:57:40 »
I've had it happen with the lasered POM ones too.  Cherry why, etc.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #18 on: Sun, 13 April 2014, 19:27:22 »
All G81 have offset stems on 1.25 modifiers. There is a reason for that madness, which is the membrane matrix is universal for 1.25 and 1.5 mod models and due to trace routing the switch position couldn't be centered. I still think it was dumb, as I can't imagine printing different membranes would cost more than producing new keycap tooling and having to make multiple versions of the same key but... yeah.
As far as in built stabilizers, there is no such thing for doubleshots, at least that I have ever seen so there is no worry. I've yet to see that on POMs either, but I suppose they may have started doing so more recently. You can use those inbuilt stab clip keycaps with costars though.
Offline Pacifist
  • on hiatus
« Reply #19 on: Sun, 13 April 2014, 19:36:56 »
oh so 1.5 is centered, but only 1.5
because i remember a thread about g81-1800 with 1.5x mods, and it was center stemmed
« Reply #20 on: Sun, 13 April 2014, 20:16:18 »
Right 1.5 is always all normal, no problem on G80 or whatever other MX that use it. Surprisingly enough it seems Cherry may still be producing 1.5 models with AT cables. At least they still were as recently as 2009 as I have a G81-1800H**US-02 I picked up NOS not too long ago.
Offline Dubsgalore
« Reply #21 on: Sun, 13 April 2014, 20:57:43 »
right: it's not just POS. It's all G81
Offline Dubsgalore
« Reply #22 on: Sun, 13 April 2014, 21:01:22 »
I believe that's thin PBT only as well
Offline Pacifist
  • on hiatus
« Reply #23 on: Sun, 13 April 2014, 21:01:41 »
well actually now I know its inbetween
its all G81 with 1.25x mods, but not for all G81 with 1.5x mods
Offline Dubsgalore
« Reply #24 on: Sun, 13 April 2014, 21:02:53 »
For G81s...the 1.25 mods are off centered...yes
Offline Candyflip
« Reply #25 on: Mon, 14 April 2014, 06:16:59 »
We were talking about mods that will be compatible with his Filco in other words 1.25u mods, why are 1.5u mods even discussed? For 1.25 I haven't encountered center stemmed for MY model...
