Author Topic: I need help to find a keyboard like this for a present  (Read 2331 times)
Offline elafito
« on: Sun, 13 April 2014, 18:14:56 »
Hi,
    I am looking for a TKL with brown switches with white and purple keycaps similar to this: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=809
I would prefer a white case (backlit or not), and I would not want to spend more than $150.
Any ideas? The best option I have seen so far is to buy a WASD and just choose the keycaps colors I want.
Thank you!
Offline Pacifist
  • on hiatus
Re: I need help to find a keyboard like this for a present
« Reply #1 on: Sun, 13 April 2014, 18:22:27 »
taobao may have the keyset, but WASD wont be backlit and the keycap quality is **** there
Id say buy the ducky at mk and paint the case yourself
Offline eth0s
  • Peace & Love
« Reply #2 on: Sun, 13 April 2014, 18:23:59 »
Hi,
Thank you!
Guise,
There has to be a better solution that a back-lit Ducky Shine.  I'm not an expert on MX anymore, so you gotta pick up the slack.
Offline Pacifist
  • on hiatus
« Reply #3 on: Sun, 13 April 2014, 18:33:06 »
finding the keycaps is the hardest part :-X
« Reply #4 on: Sun, 13 April 2014, 22:44:54 »
Welcome to Geekhack!
The keyboard you linked is apparently a custom board.
Given that mk.com have produced one custom, maybe they can produce another.
Have you tried contacting them?
Offline Oobly
« Reply #5 on: Mon, 14 April 2014, 03:08:55 »
Filco and Keycool both make TKL boards with white cases. Maybe mechanicalkeyboards could put it together for you, since they should be able to get the keycaps easiest.
Finding a purple and white set like that yourself will not be easy and may end up costing a fair amount.
If they won't, there is a Group Buy for pink and white caps at the moment, perhaps you could pick up a cancelled order: http://geekhack.org/index.php?topic=49198.0
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline elafito
« Reply #6 on: Mon, 14 April 2014, 08:24:51 »
Thank you for the help. I will contact MK and see what they say.
Offline EvillePanda
« Reply #7 on: Mon, 14 April 2014, 09:15:46 »
That is a lovely board.  I think I'm gonna have to see what else those little ****ens at MK have hiding...  Good luck finding the one you want.  Please let us know if MK will do a custom for you.
Offline Oobly
« Reply #8 on: Tue, 15 April 2014, 10:23:39 »
I just discovered this: http://deskthority.net/marketplace-f11/interest-check-for-gmk-doubleshots-t4553.html
An old group buy started by Ivan. If mechanicalkeyboards don't come through for you, perhaps you could find a way to make the set of keycaps happen still.
