Author Topic: Possible Filco TKL Modifications  (Read 3045 times)
Offline kishagi
  • Narcoleptic
« on: Thu, 17 April 2014, 10:13:05 »
Hi everybody,
I was wondering what mods are there that I could do to my Filco Majestouch II Ninja.
So far all Ive really done is change the keycaps to those side-printed white PBT keycaps, the Nickel NERV, Mario and Luigi Logos, and White/Orange Nuclear key.
So any suggestions?
Thanks for your help!!!
Re: Possible Filco TKL Modifications
« Reply #1 on: Thu, 17 April 2014, 10:20:33 »
Is there something you don't like about it?
Or something you want it to do differently or better?
« Reply #2 on: Thu, 17 April 2014, 10:28:35 »
You could:
Those are a few things you could do, depending on your comfort level with modding keyboards. :)
And, here is BlueBär's Beginner guide to keyboard modding
« Last Edit: Thu, 17 April 2014, 10:31:41 by jdcarpe »
Offline kishagi
  • Narcoleptic
« Reply #3 on: Thu, 17 April 2014, 17:20:49 »
Well I wanted to:
- make the usb cord separatable  from the keyboard
- Change the switches to Cherry MX Dark Greys or 80g springs
- Change the Caps Lock and Scroll Lock LEDs to either White or Purple LEDs
- Do that center stem mod on my stepped caps lock keycap
- Switch from Costar stabilizers to Cherry Plate-Mounted Stabilizers
- Dye my keycaps, and paint the case top (orange, grey, white colour scheme)
oh and give it spinners and neon as well.
But besides that, what else is possible?
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« Reply #4 on: Sat, 19 April 2014, 00:42:35 »
How about adding neon backlighting and adding 8 port USB hub (thinking out loud :) )
Happy Friday...
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
