Author Topic: Opinions on Dental Floss BS  (Read 2122 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« on: Wed, 23 April 2014, 20:27:07 »
Just got in my first Model M, courtesy of riotonthebay :D, and I'm still trying to decide whether I'm feelin the floss. I do enjoy the sound, but it obviously dampens the "click". So what are your opinions?
Re: Opinions on Dental Floss BS
« Reply #1 on: Wed, 23 April 2014, 20:35:26 »
When I type on buckling spring switches, I want everyone around me, including myself, to duck for cover. I embrace the banjo meets Maxim machine gun sound of BS.
I vote for no floss mod.
« Reply #2 on: Wed, 23 April 2014, 20:51:19 »
The floss mod is essential on the Model F and makes it perfect.
On the Model M, it does reduce the noise but deadens the feel quite a bit.
The F is "live" enough to take it in stride, the M really loses something.
- D Trump 2026-10-24
Offline Pacifist
  • on hiatus
« Reply #3 on: Wed, 23 April 2014, 20:55:52 »
I have 4 packages of super floss waiting to be flossed modded. But I don't want to remove the caps again...making sure the springs are aligined in the first place is so tedious
« Reply #4 on: Thu, 24 April 2014, 06:51:54 »
But I don't want to remove the caps again...making sure the springs are aligned in the first place is so tedious
Ha Ha Ha Ha Ha
I assume that all the caps will come off and on at least twice during every mod project, usually more. Once you get used to it, you can do it with your eyes closed.
If you are careful to keep the stem centered, and use a top-down rocking motion, it is really not so bad. Also, it sometimes helps to tip the keyboard up on the front (spacebar) edge to make the springs flop downward.
One word of caution: if you cut the floss too long, it will prevent the spring from seating at the top of the stem.
« Reply #5 on: Thu, 24 April 2014, 09:19:40 »
If it dampens the click, then you are doing it wrong.
Floss cut at the right length will keep the click (sound and tactility) but remove the "twang".
