Author Topic: Fluorescent Green QFR top case  (Read 44024 times)
Offline tigersharkdude
« on: Thu, 24 April 2014, 10:44:23 »
I recently purchased an extra top case for my QFR and painted it fluorescent green to match the green/black theme of my PC
If you follow this link there are more pics and info http://imgur.com/a/Br9kY
Painting the Quckfire Rapid top case is fairly simple.
I don't have any pics of the top case before laying down the 2-in-1 base coat but PREP PREP PREP and PREP some more.
I used 600 grit sand paper and spent at least 2 hours sanding all of the rubberized material off. After sanding I blew all of the dust off and wiped it down and let it dry for about an hour before painting.
 DON'T BUY CRAPPY PAINT! (IE; Valspar 2 in 1)! I've painted a lot of stuff with spray paint and this was by far the worst paint Ive ever used. It didn't cover well at all and it covered everything in green dust (NOTE: not sticky paint type dust but rather sawdust feeling crap that easily rinsed off)
After about 6 coats of the 2-in-1 (yes, 6 coats!) Coverage was absolutely terrible. I threw the can in the trash and took myself to walmart and picked up some Krylon Fluorescent Green spray paint.
Since I already had a primer/base coat down I decided NOT to cover that with a primer, I used the Valspar as a primer BUT I recommend using a primer before paint and not 2 in 1 (learn from my mistake).  When I got back home with the Krylon Flourescent Green paint I did a light sanding with some 1,000 grit for a smooth surface (you likely wont need to this unless your paint choice sucked too).
I laid down 4-5 coats of the Krylon Flourescent Green and was happy.
After the paint dried I used this Rust-oleum Crystal Clear Enamel for a hard clear coat. When ever I am spray painting I always use this for Clearcoat because it dries very thick and has a nice shine.
After ???? coats of clear I let it sit for about 24 hours to dry before putting it back on the keyboard.
« Last Edit: Thu, 24 April 2014, 10:49:58 by tigersharkdude »
Offline lightsout714
Re: Fluorescent Green QFR top case
« Reply #1 on: Thu, 24 April 2014, 10:58:13 »
That's pretty sick I like it.
« Reply #2 on: Thu, 24 April 2014, 22:21:44 »
Nice shade of green :)
Offline Lain1911
  • God of the Wired
« Reply #3 on: Thu, 24 April 2014, 22:59:05 »
Green + Black + Pistol = Win.
« Reply #4 on: Fri, 25 April 2014, 13:09:04 »
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #5 on: Fri, 25 April 2014, 13:20:55 »
Mmmh, toxic/neon green...
I wish they would sell cases in this color!
A Ghost From The Past
« Reply #6 on: Fri, 25 April 2014, 17:34:47 »
Do you have a pic that shows it from the top? Just curious what caps you have on there.
« Reply #7 on: Fri, 25 April 2014, 21:30:40 »
paint yours! Its pretty simple
they are a black/green set from WASD Keyboards
I am thinking about getting into the Toxic groupbuy
« Last Edit: Fri, 25 April 2014, 21:41:41 by tigersharkdude »
« Reply #8 on: Fri, 25 April 2014, 22:06:55 »
Thanks for the pics.
Offline sockit2me
« Reply #9 on: Sat, 26 April 2014, 03:25:18 »
Saw this on reddit! looks amazinggg
« Reply #10 on: Sat, 26 April 2014, 12:26:18 »
Potato cam :(
gracias
« Reply #11 on: Sat, 26 April 2014, 12:51:36 »
Wow, looking hot!
  • ~ BOOO ~
« Reply #12 on: Mon, 28 April 2014, 04:58:08 »
Perhaps I will...
I love neon green! :))
« Reply #13 on: Mon, 28 April 2014, 06:22:19 »
Perhaps I will...
I love that setup, but every time I see it I can't help but imagine what it would look like in yellow :D
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #14 on: Mon, 28 April 2014, 07:25:29 »
Nicely done!
Quote from: Samuel Adams
« Reply #15 on: Mon, 28 April 2014, 08:43:19 »
Perhaps I will...
  • ~ BOOO ~
« Reply #16 on: Mon, 28 April 2014, 10:28:31 »
Perhaps I will...
And I wonder what it would look like in fluorescent purple :D
Time to fire up Photoshop...
Offline slickmamba
« Reply #17 on: Fri, 02 May 2014, 21:05:02 »
I second purple!  What lens are you using?
Hi :)
  • ~ BOOO ~
« Reply #18 on: Fri, 02 May 2014, 21:41:11 »
Can't remember...
Probably was the Canon EF-S 15-85 or the EF 35L stopped down >.>
Offline slickmamba
« Reply #19 on: Fri, 02 May 2014, 22:18:35 »
Can't remember...
Haha, probably the 35?  Can't imagine getting such a shallow dof on the 15-85, unless you were at 85!  Either way awesome!  Time for me to get a 60 or 75% board!
Hi :)
« Reply #20 on: Sat, 03 May 2014, 07:29:02 »
Can't remember...
lens is a Canon 50mm f/1.8
Can't remember...
I really like the look of 60% boards, but they are too small for me. My hands are that big, but even on the QFR I feel like it's smaller than I'm used to
« Last Edit: Sat, 03 May 2014, 07:31:36 by tigersharkdude »
  • ~ BOOO ~
« Reply #21 on: Sat, 03 May 2014, 08:05:05 »
Can't remember...
You me confused with tigersharkdude, the pretty QFR is his work ;)
  • ~ BOOO ~
« Reply #22 on: Sat, 03 May 2014, 08:10:02 »
Btw, it seems to be impossible to get Krylon spraypaint around here... :/
Someone knows a good brand that offers neon-green and is easily available in Europe?
« Reply #23 on: Fri, 09 May 2014, 12:01:33 »
Im in the US so I will just throw out a few names that Ive seen bright green in
  • Testors
  • VHT
  • Rustoleum
Offline metal1091
« Reply #24 on: Mon, 19 May 2014, 17:15:12 »
Damn that looks good  :thumb:
Offline agent181
« Reply #25 on: Thu, 16 October 2014, 23:49:10 »
So where can i get my hands on that wood wrist wrest
« Reply #26 on: Fri, 17 October 2014, 11:01:02 »
I was making them a while back but my table saw is done-zo and I never bought a new one
Offline Anole
« Reply #27 on: Wed, 11 February 2015, 18:57:51 »
That looks sick!  :p
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #28 on: Wed, 11 February 2015, 20:27:53 »
Nice man! this is basically what i'm going for with my GON, with lighting.
GON NerD TKL DTA Edition
« Reply #29 on: Thu, 12 February 2015, 13:18:26 »
FWIW the vibrant green got on my nerves FAST (I don't think it was green for a month before I changed it).
whatever color you decide to paint your case be sure it's something you really enjoy or you will be repainting due to it being obnoxious.
« Reply #30 on: Thu, 12 February 2015, 14:47:01 »
YELLOW!!1!11
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #31 on: Thu, 12 February 2015, 19:01:13 »
I didn't notice how old this post was till now lol
Offline burn1nsun
    • My stupid YouTube Channel
« Reply #32 on: Sat, 02 May 2015, 14:15:26 »
Green apple
HHKB Pro 2 l Pok3r Gateron Blacks
