Author Topic: Originative dolch question  (Read 2869 times)
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
« on: Sat, 26 April 2014, 00:47:52 »
Do originative dolch keycaps work with costar stabilizers? Also, do they look identical to the authentic dolch caps? I am thinking of getting the extension to mix with the authentic pac 62 caps to out on my filco, and I need to make sure of these two things first. Thanks!
Offline Sniping
Re: Originative dolch question
« Reply #1 on: Sat, 26 April 2014, 00:51:04 »
Your original keycaps may be a bit discolored or yellow so it might look a bit different because of that.
« Reply #2 on: Sat, 26 April 2014, 00:54:05 »
If it works with Cherry stabilizers, it works with Costar stabilizers....unless something is seriously wrong.  I couldn't say if they look identical, but if someone is willing to loan me some Originative Dolch, I could tell you.
If you want an original set, I give some advice here on how to find an affordable set.
Edit:  Personally, I wouldn't buy from Originative.  Sherry is a great guy, but flaky as hell.  Until you know for sure that he's definitely back, don't buy from him...that and unless you know you'll get a perfect set, don't buy from him.
« Last Edit: Sat, 26 April 2014, 01:00:24 by nubbinator »
Offline epzy
  • HHKB Fiend
  • ded
« Reply #3 on: Sat, 26 April 2014, 00:59:01 »
"Do originative dolch keycaps work with costar stabilizers?" Yes they do. I have a GMK Dolch set on my Filco Majestouch 2 as we speak.
Offline CK Briefs
  • formerly calvins1
« Reply #4 on: Sat, 26 April 2014, 01:00:20 »
'If the hole fits, then the key cap sits' - Nostradamus
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
« Reply #5 on: Sat, 26 April 2014, 08:12:03 »
If the keycap set was made for Cherry MX switches, then it will fit both Costar and Cherry stabilisers.
There are keys on other keyboards, such as Cherry MY, BTC rubber dome, several vintage switches etc where the 1×1 keys fit Cherry MX, but where the stabilisers are different.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #6 on: Sat, 26 April 2014, 08:27:04 »
Some BSP sets have problems with Costar stabs if I remember correctly.
Offline gotofbi
« Reply #7 on: Mon, 28 April 2014, 20:36:16 »
should be fine
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #8 on: Mon, 28 April 2014, 20:37:35 »
should be fine
lol, you waited 2 years for that?
And welcome to GH
« Last Edit: Mon, 28 April 2014, 20:44:12 by hwood34 »
« Reply #9 on: Mon, 28 April 2014, 20:39:10 »
should be fine
better than nothing
and the proper response is, "Welcome to GH!"
