Author Topic: Filco Majestouch Tenkey Pad not working in Arch Linux..  (Read 1647 times)
Offline esko997
  • Linux Lover
« on: Mon, 28 April 2014, 20:16:08 »
Hey Geekhack,
Just wondering if anyone has experience with this issue.
When I plug in the tenkey pad it works fine, (Home, End, Pg Dn, etc.) but when I turn on Numlock and try to start entering numbers it appears to lock up and stop responding. Unplugging it and pluging it in again get it back to normal, but again as soon as I go to do number entry it freezes up after inputing 1 or 2 numbers. Searching Google came up with a post on the askubuntu website and apparently the guy who was having the issue just upgraded to Ubuntu 13.04 and his problem was solved, I'm using Arch Linux however.
Just wondering if anyone had any fixes for this. Is there maybe a driver I'm missing?
Thanks all
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Offline donhalcon
Re: Filco Majestouch Tenkey Pad not working in Arch Linux..
« Reply #1 on: Wed, 09 July 2014, 20:31:43 »
I'm having the same issue with Debian on the testing branch.
I suspect a problem in the kernel, but haven't had time to debug it yet.
Linux 3.13-1-amd64 #1 SMP Debian 3.13.10-1 (2014-04-15) x86_64 GNU/Linux
