Author Topic: I'm in need of a good soldering station  (Read 5219 times)
Offline TopazPie
« on: Tue, 29 April 2014, 00:19:59 »
Hey, everyone. I'm finally getting rid of my $7 soldering iron and going to get a better one. Thanks for the input in advance.
Offline Beca
  • what am i doing with my life
Offline TopazPie
Re: I'm in need of a good soldering station
« Reply #2 on: Tue, 29 April 2014, 00:22:17 »
Haha thanks. Not sure why I didn't see this when I searched.
Offline Beca
« Reply #3 on: Tue, 29 April 2014, 00:31:48 »
np. and I've personally heard some good things about this station: http://www.hobbyking.com/hobbyking/store/__19240__soldering_station_with_adjustable_heat_range_usa_warehouse_.html
it's called the yihua 936 and it's a clone of a hakko station. it's like $30 shipped i believe, around there. I have not personally used it myself, I just google yihua 936 and read some feedback on it.
Offline TopazPie
« Reply #4 on: Tue, 29 April 2014, 00:40:57 »
Interesting. I am not sure that I want to chance it not being as good. I might just get a hakko station.
Offline Beca
« Reply #5 on: Tue, 29 April 2014, 00:51:06 »
you could, im just poor as **** so this is something i'd probably get :p
Offline Pacifist
  • on hiatus
« Reply #6 on: Tue, 29 April 2014, 01:12:12 »
+1 solid entry iron
Offline Lanx
« Reply #7 on: Tue, 29 April 2014, 14:01:57 »
those are the chinese clones of the hakko 936, another popular clone is the
AOYUE 936
i'm not a soldering expert, but the reason why you want to upgrade from a 7$ radio shack pen solder is to get control, like super temp control, why would you ever trust ****ty chinese copy cats for that?
i've used my hakko 936 for 2 boards and a few electronic stuffs, it's LOADS easier than a ****ing radio shack pen, the upgrade is amazing. i've also used it to de-solder, just get the sucking pen.
Offline TheSoulhunter
  • ~ GHOST ~
« Reply #8 on: Tue, 29 April 2014, 16:01:58 »
Might help to decide...
Offline Lanx
« Reply #9 on: Tue, 29 April 2014, 16:26:06 »
tldr, buy if you are absolutely dirt poor, it's at least better than solder pens.
good review
« Reply #10 on: Tue, 29 April 2014, 22:45:42 »
I recommend OKI / Metcal. They are excellent!
 I really want to try pace or JBC though.
Offline bazh
« Reply #11 on: Tue, 29 April 2014, 22:55:40 »
I use Goot PX-201, likely $50 on amazon
HHKB Pro2 white
Newbie again
Offline physicsmajor
« Reply #12 on: Fri, 16 May 2014, 20:18:31 »
+1 for the Hakko FX-888[D]
If you can find the original FX-888 analog version in very good condition used, consider it. Strongly.
Offline intelli78
« Reply #13 on: Fri, 16 May 2014, 20:28:59 »
I bought a Hakko FX888D from Amazon a few weeks ago, and I have been very happy with it. Just your basic, temp controlled station. From what I read, Hakko and Weller seem to be two of the most reputable brands.
« Reply #14 on: Fri, 16 May 2014, 20:45:25 »
Make sure to feed it good quality solder, too. You want the leaded stuff with rosin or flux core. Kester 44 is my go-to. Almost equally as important as the iron to make the entire experience positive...
« Reply #15 on: Sat, 17 May 2014, 19:23:02 »
agreed: get decent solder. it makes everything easier.
I have a few lbs of "indium" brand solder that is excellent.
« Reply #16 on: Sun, 18 May 2014, 23:47:14 »
To elaborate a bit: "Decent" solder means leaded solder (the Pb is a good thing, not bad, for this purpose) which also has rosin or flux in the core. Kester 44 is a front running option, it flows like magic.
Offline EverythingIBM
« Reply #17 on: Sat, 24 May 2014, 19:22:11 »
I'd definitely recommend leaded solder (like 60/40 w/ rosin core). Honestly, it is not dangerous.. the only dangerous thing with soldering are the fumes from the flux.
If you do a lot of through-hole soldering, get a Hakko-808. It also works very well to not only desolder leads, but solder and reflow them as well.
Offline phoenix1234
« Reply #18 on: Sat, 24 May 2014, 19:32:16 »
Personally, my suggestion is to find the brand Edsyn if you are based in the US.
Edsyn 951sxe soldering station that http://www.geekhackers.org/ is selling is a great station
http://geekhack.org/index.php?topic=57764.0
Otherwise, you can get a Goot PX-501 or Ersa i-Con Nano if you are based in Asia or EU.
« Last Edit: Sat, 24 May 2014, 19:35:58 by phoenix1234 »
I like linear switches
