Author Topic: Painting the keyboard case  (Read 2166 times)
Offline Pinder
« on: Mon, 05 May 2014, 10:46:53 »
I've had my steelseries 6gv2 for 5 months now, i like it however there isnt alot of customisation options. You cant get new cases, you cant get a set of keys and not many other people have them and can give you tips on how to do things. Im thinking about taking it apart and painting the case and the keycaps but im not sure what type of paint to use or if i should sand the plastic down
can someone give me some tips about this
65g zealios ergodox infinity
Re: Painting the keyboard case
« Reply #1 on: Mon, 05 May 2014, 10:49:37 »
Here's a tip. It's not related to the question you asked in OP, but it's a good tip nonetheless.
Use the search function.
If the search function fails then ask here.
If that fails then make a new topic.
You've made 5 threads in the past 24 hours, 4 of which were questions that could've been answered by using the search function.
« Reply #2 on: Mon, 05 May 2014, 11:04:31 »
Just FYI, this is the best way to search the forum, IMO. Just type or copy the following into the address bar of your browser, replacing the bold capitalized text with your keywords to search:
Code: [Select]
https://www.google.com/#q=site:geekhack.org KEYWORDS TO SEARCH
Here are some beginner's modding tips I gathered:
You could:
Those are a few things you could do, depending on your comfort level with modding keyboards. :)
And, here is BlueBär's Beginner guide to keyboard modding
