Author Topic: [IC] JD40 40% boards: metal, plastic, and a celebration of smallfry's life  (Read 43497 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Folks,
I've been talking to a number of people who want to come together and celebrate smallfry's life. Yesterday, we bounced the idea of a 110 red on red keyset that harkens to one of his favorite boards. We've been talking about the economics of it, and what we've come up with instead is a group buy of JD40 40% boards. I'll let jdcarpe talk about how he and smallfry worked together on the 40% board idea, but the basic idea for the GB will be pretty simple from a participant's point of view.
We are going to build kits to make JD40 boards. The layout will not be customizable. It will be a basic winkeyless layout with possible one small change for a key that acknowledges and celebrates nathan's profound influence on the board, both the keyboard and the forum.
each kit will come with:
1x titanium switch plate
1x PCB
2x acrylic spacers
1x aluminum bottom plate
1x bumpon kit
1x red on red keyset designed specifically for this board
1x titanium bottom plate
1x sorbothane spacer gasket
1x PCB
1x bumpon kit
1x fastener set
the smaller size of the keyset will keep keyset costs reasonable. the titanium will be polymer coated for durability, and the aluminum will be either protected or colored via anodization or powder.
any and all money made on this GB over the cost of materials and labor will go towards the nathaniel j walter foundation. assembly services will be available, details TBD.
we miss you nathan. :(
64073-0
64075-1
update: regardless of what goes under the titanium switch plate, the switch plate will NOT have switch-opening notches. If you want switch-opening notches: head here http://geekhack.org/index.php?topic=58073.msg1333490#msg1333490 to purchase. limited quantity available. Note that proceeds from the notched switch plates will not go to the NJW foundation.
« Last Edit: Mon, 02 June 2014, 19:08:10 by mkawa »
Offline tjweir
Great cause, great board and colourway.
Interested.
I am also in for this.
Offline yicaoyimu
Is it possible to get just JD40 kit without caps?
Any idea on how many will be produced?
Offline Vibex
  • Love y'all
I'm certainly interested.
Can we get the caps without the board?
^^ compromise? :D
Offline geniekid
Am I correct in interpreting this as the physical layout not being customizable but the controller (Teensy?) still being fully programmable?  For that matter, do we need to supply our own controller?
Offline mkawa
^^ compromise? :D
hah! sounds good to me :)
to simplify things, sets will come with all of the items listed
Offline mkawa
yes, and good question. jd has dealt with pjrc before from the previous GB. since fulfillment will probably just be JD and I, it should be easy to include a teensy with the kit.
as for how many will be made, we have to determine the multiples of units that can be yielded from each piece of material, but we generally want to include everyone who wants one.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Making the caps available on the side would allow us who already have a JD40 to participate, which would be much appreciated. It shouldn't drastically complicate things since caps will already have to be a separate order from PCB's/plates…
Just wanted to add a little note here. SmallFry didn't really design the 40% keyboard with me, but he was very supportive of my design in our personal conversations. It was the first new design of mine to be realized after we lost SmallFry, so I decided I should name the new keyboard after him. Regack was kind enough to include the dedication to SmallFry on the new revision PCBs, but these older revision PCBs won't have that.
We should probably include a Teensy and header pins with each kit, as well as diodes and a few other components that will be needed to build these.
Offline JPG
  • Model F is my new passion!
I don't want to derail this topic at all, but anyone know where he found his keyset for the F122?
Offline Grendel
Interested ! :)
- I'm game !
He Rit dyed them.
Offline mkawa
one of the major problems is that unless there are a lot of takers, we would like to limit the cap set to 40% for pricing reasons
He's asking if the 40% keyset can be made available to people separate from the keyboard kit. Because there are a few of these keyboards already in the wild now.
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
Colour me interested  :thumb:
Offline mkawa
oh, sure.
Yup, JD and Riot got me covered :D.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Is there any sort of a rough ballpark idea on price for these?  I would love to try out a 40%.  It will be one hell of a transition from full sized.
Offline BlueBär
I know you sell JD40 kits for 200$, now this even has a titanium plate and a keyset so I suppose the price will be quite high? I am interested in one but I don't know how much I would pay for this :-X
Offline Melvang
Thanks bluebar.  Looks like I need to get this bolt modded M of mine sold pretty quickly.
Well, that is with switches, and assembly labor. And the fact that I order the components in small batches keeps the price high for me.
In some volume order, the PCBs will be cheaper, plates will be cheaper (well, the Ti will be more expensive, but you get what I mean), etc.
Any chance the new 40% PCB will be ready?
Offline BlueBär
With that amount of switches they don't make a big impact though :))
Well as I said it depends on the price for me. I like the 40% form factor, it's just cute :3
On the other side I don't know if I could use a 40% as my main keyboard, which is what held me off of buying one.
Offline mkawa
we're looking at ti switch plates only. a ton of 40%s can fit on one of these sheets. further, i have been working with my cutter on reducing cutting cost significantly.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
I'm 100% in.
Offline Yslen
Potentially in. I've been waiting on the development of JD's 40% design and for a kit to become available. What's the layout going to be, exactly? I had some caps already in mind for a 40% but if it's winkeyless they will probably not fit...
EDIT: I've ordered these with the hope I'd be able to use them on a JD40/SmallFry board, at some point.
Also, if this is the first version of the PCB, what's it lacking vs. the revised version that's still in the works? Sorry if this information is already out there somewhere and I've missed it.
« Last Edit: Thu, 08 May 2014, 21:27:37 by Yslen »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
totally in for this. I've been moving down in size since my very first fullsize, so I guess this is the final progression
Offline Zeal
    • Zeal Generation Inc.
Hm, this'll be interesting. I just hope the 40% layout won't mess me up when I type on other keyboards.  :p
Offline tbc
I AM IN
so so freaking in.
titanium. awesome.
40%.  baller.
self assembly.  OH YA.
'skin' case layering.   :cool:
led support?
comes with switch tool?
« Last Edit: Fri, 09 May 2014, 03:47:21 by tbc »
Offline mkawa
switch tools would have to be coordinated with the_beast if there are any droppings left that could be used to cut them
Offline mkawa
would people prefer a titanium bottom plate or is aluminum fine? the advantage of titanium is: it looks cool and it is a heck of a lot stronger than aluminum sheet.
Offline mkawa
also, we can get little aluminum feet made. i don't think this will add much marginal cost to the price, and we have drawings for these already
Offline AKmalamute
  • HHKB Scrub
You might get a larger overall saturation if you offered both: aluminum to the folks whose wallet hasn't recovered from its last hack, and Ti for those in a position to go all the way.
HHKB-lite2, Dvorak user
Offline mkawa
if we do two materials, the labor cost of cutting is going to double, which will negate any potential cost savings. volume and uniformity is essential to cost cutting
Offline Vibex
  • Love y'all
I would prefer Titanium personally.
And I would love to have feet. Much more important to me then the Titanium bottom plate, though I would still love that. ;D
Offline Zeal
How much would Titanium top, bottom & feet cost?  :cool:
Offline Grendel
I would prefer an Al bottom plate since it's lighter (planning for a board to carry around. Every g counts :) )
- I'm game !
Offline mkawa
titanium would be lighter because the aluminum sheet would need to be thicker to get the same rigidity
Offline mkawa
i don't have access to the thickness of titanium needed to make feet. they would be 6061 alu
cost depends on how we end up building this thing and how many get made.
Offline Grendel
Ah, I will change my preference to Ti in that case. :)
- I'm game !
Titanium bottom + feet is my vote.
Offline Melvang
Ti top, ti bottom, and aluminum feet in brushed.
Offline minho
  • i'm kind of back
Potentially interested, it looks quite alluring though.
Offline mkawa
i think we're going to run a prototype of this with top and bottom titanium (no feet yet -- that will take some time to grab the drawings and gathering quotes)
Offline dante
With a layout this small wouldn't a plate be overkill?
Offline Melvang
No because TITANIUM.
