Author Topic: Panda Clears and Ghost Blacks are better than Stock Clears and Stock Blacks  (Read 10416 times)
Offline Defect
OOOOOOOOOOOOOOOOOOOOOOOOOO
Panda Clears > 62g Lubed and Ghost Blacks are the best gaming switch.
Bring it on.
Edit to make post less trolly:
Swapping the 60 cherry spring in blacks with the 65/80 spring in clears is a better match imo.  These should be the default switches
Clear spring in clears makes them too mushy, but clear spring is black is great for gaming.  NEVER bottom out, feel like my fingers are always supported, and to actuate the switch takes little force.  Bottoming out requires a lot of force (80g).  Don't say anything until you've tried it.  I SWEAR BY IT.  Ghost blacks are god tier for gaming.
And clears with black spring are snappier than stock clears on the upstroke, and (opinion) are more joyful to type on.  Especially with super thick pbt and no lube on the bump (but lube on sliders)
« Last Edit: Fri, 09 May 2014, 09:49:58 by Defect »
Offline keymaster
  • Topre Revolution Theorist
Warning: Preferences and opinions ahead
This is a good thread. Good job OP :thumb:
#Thorpe
Offline Xowie
  • On Sabbatical
10/10, would read again.
RETIRED
Offline Blackehart
scissor switch?
To be fair, Panda Clears are pretty much better than anything.
Offline Zeal
    • Zeal Generation Inc.
Incoming lubed, 62g #GOLD clears.
Offline Defect
About to desolder and replace with pandas.  /gg
What to do with 200 lubed 62g springs?
Offline Zeal
Record yourself burning it.
Offline CK Briefs
  • formerly calvins1
It's not about the #goldspringsburning, it's about sending a message.
Current Keyboards: Orion - 62g ergo clears;
A87 PS2AVR - 59g ergo clears; QFR - stock blues
Offline Zeal
Actually, do the kirkle test. Microwave all 200 switches for a couple minutes, and see if cherry mx switches are microwave proof.
If they survive, bring on the blow torch.
Offline daerid
    • Rossipedia
Stock all the way.
COME AT ME BRO
Offline Zeal
Stock all the way.
COME AT ME BRO
o**** son, that's rough.
Offline Pacifist
  • on hiatus
clears literature is so convoluted
first there's the classic 62g ergo clear (of which there is regular, limited, and #gold) then you got your stock clear enthusiasts, panda clears, and then there is 45g with thin lube. Also 65g, 67g, all kinds of people who prefer different weights for the same stem
« Last Edit: Fri, 09 May 2014, 01:30:30 by Pacifist »
Offline Zeal
Clears with 200g #GOLD springs, lubed. New super clear switch.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Rockin the thin lubed clears with springs from year and a half old browns.  Not one switch sticks.  Though the space bar is a stock clear spring with thin lube.
Offline feizor
So if you just swap the springs on stock clears and stock blacks, you get two ideal switches?
Offline Zeal
"Ideal" switch feel is subjective.
Offline Defect
Yeah, I was 1. having fun 2. being serious.
Started swapping switches for a gaming board rotation (rather than my usual switch tests) and started to find that ghost blacks are AMAZING for gaming.  Also found that (without lube) panda clears are much snappier on the upstroke than stock clears.  They feel less mushy, too, and mushiness is often a big complaint with stock clears.
Clear spring with black stem does also have this mushiness, only it feels more like cushioniness (lol words).  Typing on ghost blacks is pretty weird, and pressing ghost blacks without a board plugged in feels bad.  But if you've ever gamed on it (I rotated hours of RTS and FPS), its absolutely amazing.  The strength of that heavy spring makes the key feel like it reacts faster.  On lighter switches I find that my fingers fatigue more than they do with these padded feeling ghost blacks.
But yes, it is all opinion.  What else is new, we all know that.  I'm sharing because I found through weeks of rotating that taking these two stock switches and swapping springs gives better spring/stem matches.  I wish these were the default setups rather than what they are now, and I encourage many people to try it out!
Offline genkidama
What are Panda Clears? Ghost Blacks? Gold Clears? :confused: :confused:
Who am I? Where am I? What am I?   :confused: :confused:
I feel like I've been away for like a decade and new forms of keys pop up on every corner of my fine geekhack universe.
I just want Ergo Clears  ^-^
My finger training is over 9000!!!!
Stock all the way.
COME AT ME BRO
This guy know whats up. :thumb:
Offline Defect
Actually working on an info graphic for this.  Busy week at work though so we'll see when I can post.
Basically,  ergo usually means light spring, can mean cherry 45/50 or korean 62 or anything really.  Some would say Panda clears are a form of ergo
Panda is black spring
Ghost is clear spring
62g usually refers to korean.  Gold plate optional (really I don't think it affects anything.   Looks great for hobby build pictures though)
Offline TheSoulhunter
  • ~ BOOO ~
70g Clears and Ghost Blacks FTW!
A Ghost From The Past
Offline Sagii
  • Time to bust some nails
Screw you guys and your switches ! :c now I'd decided on brown cherry switches, after debating wether I'd get clears or browns for ages. Now I'm unsure again.  I hate you guys :(
Panda clears do sound nice though
« Last Edit: Fri, 09 May 2014, 10:30:43 by Sagii »
Offline Folio
  • I'm a nice guy.
200g springs under brown switches. Feels good man.
Offline bazh
Black spring + Clear/White stem = Panda
Clear spring + any stem = Ghost
#GOLD is for #SWAG
HHKB Pro2 white
Newbie again
Offline Folio
  • I'm a nice guy.
#GOLD is for #SWAG
But what about #DIAMOND?
Offline Zeal
#GOLD is for #SWAG
#PLATINUM 62g springs. Get on my level. :cool:
Offline Folio
  • I'm a nice guy.
#GOLD is for #SWAG
On a more serious note, Is it really GOLD GOLD? Or is it just brass? I can't see gold holding up that well as a thin little spring being compressed up and down all the time.
I think it's spring steel plated with gold.
Offline Zeal
#GOLD is for #SWAG
No, if they were 999k gold, we'd spend more on springs than keyboards. :p (And it probably wouldn't even rebound.)
Not sure about the old "first generation" gold springs, but the recent GB sprit had were 18k gold plated springs.
Offline bazh
#GOLD is for #SWAG
plus if they were, they wouldn't be springs, gold are too soft
but, will #PLATINUM beat #TITAN?
HHKB Pro2 white
Newbie again
Offline Folio
  • I'm a nice guy.
I guess it really is just for DA SWAGGGGGGGGGGGG
  • ~ BOOO ~
No! It's to prevent corrosion when typing at 500WPM dropping all that salty sweat on the board...
Offline Zeal
If we're so into matching colours, why has no one hosted a GB for anodized springs...? Red springs for red cases, black springs for black cases, etc.
Plating diff materials on the springs makes the springs feel a little different in my opinion. If you just make different colors, unless you have a clear top, there's no way you're going to see the springs.
Offline Defect
Thread derail successful
Offline ferociousfingerings
Or you could coat the entire thing with NeverWet...
Logitech G710+
Offline handystack
:mad: I missed the clear switch case GB, and I have clear keycaps on gold plated 62g clears  :'( :'(
Why are Ghost Blacks still not mentioned in the Deskthority wiki?  They are, afterall, the best switch ever.  And no, I'm not biased in any way about that.
Offline Melvang
My guess would be due to the closeness of clear springs vs black springs.  I know they are different beasts with the clears having a much steeper compression rate.
Maybe, but they feel so dramatically different, in a good way.  There wouldn't be so many converts if that weren't the case.
Offline Melvang
If I can find the springs I might just put them in the lubed blacks I have in my WYSE, when I get around to putting that together with the Enablers (not sure if vintage or modern with a build stamp of 96).
Offline Defect
After you do that, game on them for 3 hours (consecutive if you got that fever) and then tell me Blues are for gaming (hello Razer).  "For gamers.  By gamers 3 year olds"
Offline epzy
  • HHKB Fiend
  • ded
Every switch is equal for gaming. Come @ me.
Offline Sagii
I got no clue which one is better yet. Come at me.
Seriously though.. for the small amount of time I had reds I didn't like the linear feel when gaming.
Offline Defect
All except click types (blue/green/white), which blow for gaming (just look at the engineering design..) but are an absolute JOY for typing.  Rest is personal preference which sparks endless discussion.
Once you've used all switches you learn to love them all and you'll find certain ones are better for certain tasks/times of day/current mood.
My 62g lubed blacks are still my primary for gaming and instead of swapping to ghost blacks I'm just gonna buy another 60 and put ghosts in that.  For slow pace/rts gaming at night.
62g in the morning, ghosts at night.
« Last Edit: Sat, 10 May 2014, 10:24:10 by Defect »
Offline epzy
  • HHKB Fiend
  • ded
MX Blue for LoL all day.
