Author Topic: [IC] Duck Viper and Eagle  (Read 129273 times)
Offline MrChunky
Re: [IC] Duck Viper and Eagle
« Reply #400 on: Fri, 18 July 2014, 03:22:12 »
So I found a local shop that might make me some acrylic inserts for both the Light Pad and the Viper, but what do I need to give them, just the .dxf flle Duck posted on his site?
Will they know what to do with that, because I sure as hell don't...
I don't know if we know the thickness of them.  But the files show the profile of them so if we knew the thickness it shouldnt be hard.  You would just tell him which ones you wanted (theres 4 on the file) and how many probably.
The thickness may be what 10T and 12T are but thats just a guess.
It seems they are 12T (http://kbdlab.co.kr/index.php?mid=board_tune&document_srl=153206), but might be different with V2. DXF can be opened with autocad or converted, they should be fine.
Offline Xenderwind
« Reply #401 on: Fri, 18 July 2014, 03:51:38 »
What I meant was I have no idea what 10T and 12T mean.  I just assumed it was some form of a measurement of thickness.  I would guess it just means mm thick but I would prefer if someone more knowledgeable (or with one of these boards) would confirm.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline MrChunky
« Reply #402 on: Fri, 18 July 2014, 04:00:48 »
I can check when I get home in a couple of hours, or maybe someone is quicker  :)
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #403 on: Fri, 18 July 2014, 04:33:19 »
From other posts, especially the Orion base plate it seems like this does mean the thickness in mm. I have sent the files to a company nearby to ask for a quote as well.
T = Thickness?
12T = 12mm
|||My other keyboards :
x
Offline jorgenslee
« Reply #404 on: Mon, 21 July 2014, 02:45:13 »
Does the layout of the PCB of Viper has been posted yet? I was planning to get sprit's 60% Acrylic plate, cut it and put it on the viper. Is that possible?
Offline Xenderwind
« Reply #405 on: Mon, 21 July 2014, 03:02:47 »
No idea if it is possible, I wouldn't count on it personally.  The pcb was posted a couple pages back though
should be the middle one.
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #406 on: Mon, 21 July 2014, 03:07:37 »
I might be reading too much into it, Xenderwind, but you seem to be watching this thread as obsessively as me  ;D
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline jorgenslee
« Reply #407 on: Mon, 21 July 2014, 03:11:54 »
I see. Thanks. It might be worth a try though seeing acrylic can be easily modified.
Offline Xenderwind
« Reply #408 on: Mon, 21 July 2014, 03:28:00 »
Haha, yeah I'm pretty excited XD.  I've been using tkl for so long and just recently got a 60% besides my hhkb and realized how much I like the layout.  Also realized how much I love 65g blues, especially the part where I don't have to bother lubing them.  Sad to see my GON going to get replaced though...might eventually have to sell it.
It very well might work.  To be honest I didn't look too much into the layout of the pcb and the plates from Sprit.  If I had to make a quick judgement I can see a few problems with the screw placement being off (at least thats what I assume those holes are for on the pcb).  For instance the one right below I believe its keys 6 and 7.  The screw hole for the sprit plate is actually between the switches instead.  I can see the same being a problem for the one by the enter key and maybe the shift one at the very least.
Offline jorgenslee
« Reply #409 on: Mon, 21 July 2014, 03:41:35 »
Yeah, you are right. Upon checking the plate I have, there is no single hole I can see that would match the one on Viper's PCB.
Offline Vintage
« Reply #410 on: Wed, 23 July 2014, 17:49:41 »
Does anyone know what if we should but plate mounted or pcb mounted stabs for the viper and eagle plates? I assume plate mounted but I'm not sure.
CM QFR w/ MX Reds  | Logitech G900
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #411 on: Wed, 23 July 2014, 17:51:34 »
wut?
Plate
Offline Vintage
« Reply #412 on: Wed, 23 July 2014, 18:11:03 »
thx. I thought some korean boards used pcb mount for some reason.  :p
Offline pasph
« Reply #413 on: Wed, 23 July 2014, 18:12:49 »
Usually Korean custom kbs use pcb mount stabs
Offline keyit
« Reply #414 on: Wed, 23 July 2014, 18:14:30 »
based on the pictures of the pcbs, id also think they use pcb mount stabs
boop
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #415 on: Wed, 23 July 2014, 19:08:49 »
*double checks board* yup, you're all right, PCB mount stabs
Offline Vintage
« Reply #416 on: Wed, 23 July 2014, 19:23:03 »
xD I knew I read that somewhere.
Offline elton5354
« Reply #417 on: Wed, 23 July 2014, 20:46:58 »
Yeah, that's the thickness of the insert in mm
Light Pad's
« Last Edit: Wed, 23 July 2014, 20:50:39 by elton5354 »
Offline osi
« Reply #418 on: Thu, 24 July 2014, 08:26:59 »
Hi Elton -- what would be your latest prediction for the start of the group buy for the viper/eagle kits??
inb4 - 'after lightsaver group buy'. :D
I'm actually glad this buy is slightly delayed. Allows me more time to get my paltry finances in order :D :D
  • Keyboard Hipstar
« Reply #419 on: Mon, 28 July 2014, 02:42:08 »
When desu ka?
Offline elton5354
« Reply #420 on: Tue, 29 July 2014, 21:19:38 »
I'll create the group buy tomorrow.
They already have 70 units ready for us. Just needs to be anodized.  :thumb:
Offline Zeal
    • Zeal Generation Inc.
« Reply #421 on: Tue, 29 July 2014, 21:20:49 »
#HYPE
Offline asassdsd
  • Call me "Jelly"
« Reply #422 on: Tue, 29 July 2014, 21:21:38 »
OMG OMG IM TRIPPING SO HARD
This isn't an alternative or troll account, I've been using this username for at least 10 years. Try typing it, is so fast and easy!
Recently acquired: Leopold fc660c with PBT   Currently: Bro-less    Clack-less    Mummy-less
I am currently at : Santa Cruz, CA
  • Keyboard Hipstar
« Reply #423 on: Tue, 29 July 2014, 21:26:34 »
YESSSSSSSS
How long does it take to anodize something?
« Last Edit: Tue, 29 July 2014, 21:30:50 by StylinGreymon »
Offline osi
« Reply #424 on: Tue, 29 July 2014, 21:30:43 »
my word
Offline Xenderwind
« Reply #425 on: Tue, 29 July 2014, 21:32:40 »
What?!?!  That will speed up everything so much!   Thanks elton!
Offline keyit
« Reply #426 on: Tue, 29 July 2014, 21:34:35 »
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH. im ready.
boop
« Reply #427 on: Tue, 29 July 2014, 21:36:45 »
Must resist.....
  • Keyboard Hipstar
« Reply #428 on: Tue, 29 July 2014, 21:37:09 »
Give in.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #429 on: Tue, 29 July 2014, 21:39:15 »
Mod Edit: fixed the image link. ;)
« Last Edit: Tue, 29 July 2014, 22:12:45 by infiniti »
Offline Vintage
« Reply #430 on: Tue, 29 July 2014, 22:30:25 »
SUPER EXCITED! Hopefully the form will be up before work tomorrow :D
Offline minho
  • i'm kind of back
« Reply #431 on: Tue, 29 July 2014, 23:20:59 »
Damn I'm pumped.
Offline jorgenslee
« Reply #432 on: Tue, 29 July 2014, 23:46:35 »
Hopefully there is no shortage seeing there is interest of 150 and only 70 available as of the moment.
  • Keyboard Hipstar
« Reply #433 on: Tue, 29 July 2014, 23:54:55 »
Yeah, I hope the buy is up before I go to work.
As long as I've been on top of this, it would kill me to be in the 2nd batch.
« Reply #434 on: Wed, 30 July 2014, 00:55:08 »
I AM SO READY FOR THIS.
Offline Zeal
« Reply #435 on: Wed, 30 July 2014, 01:36:32 »
YOU ALREADY HAVE 2 LIGHTSABERS
Offline tjweir
« Reply #436 on: Wed, 30 July 2014, 07:25:24 »
My body and wallet are ready!
« Reply #437 on: Wed, 30 July 2014, 08:10:02 »
I only have one!  I'm just being taunted by the other one.  :P  And all the more reason for me to be excited about Viper!  I can see the beauty...
Offline elton5354
« Reply #438 on: Wed, 30 July 2014, 08:13:18 »
Won't be up until tonight. I don't know what time you guys work, but I work during the day. ;)
I will be collecting payments right away as I think this will make this group buy a little faster and keep the buyers committed. :P
Offline osi
« Reply #439 on: Wed, 30 July 2014, 08:32:18 »
How long are you planning for the payment window to be? :D
Offline minho
  • i'm kind of back
« Reply #440 on: Wed, 30 July 2014, 10:43:38 »
Well if you have their money, I would certainly assume they are committed... :P
Is pricing the same as estimated in the IC? about $220 per PCB/case + shipping?
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #441 on: Wed, 30 July 2014, 12:45:20 »
The hype is real.
Anyone in EU offering assembly service for this buy?
Offline epzy
  • HHKB Fiend
  • ded
« Reply #442 on: Wed, 30 July 2014, 12:46:29 »
The hype is real.
http://geekhack.org/index.php?topic=50048.0
Offline pmh1410
« Reply #443 on: Wed, 30 July 2014, 12:57:18 »
I hope that Duck0113 will make Red color :P
Offline Rewind
  • Street Fighter
  • Drive slow, homie
« Reply #444 on: Wed, 30 July 2014, 13:08:54 »
The hype is real.
Awesome, thanks mate! [I'm blind :))]
Offline Fnzzy
« Reply #445 on: Wed, 30 July 2014, 13:32:55 »
It is everything I have ever hoped for! Really excited for this, first korean  :D
Offline elton5354
« Reply #446 on: Wed, 30 July 2014, 22:24:00 »
I've posted it a couple hours ago.  It just needs to be approved by the mods.  :thumb:
Offline keyit
« Reply #447 on: Wed, 30 July 2014, 22:28:42 »
can't hold back my excitement.
boop
« Reply #448 on: Wed, 30 July 2014, 22:34:58 »
Go go go!  I may have already submitted my order.
 :p
Offline Zeal
« Reply #449 on: Thu, 31 July 2014, 02:35:31 »
 :p
I bet Hoff placed first dibs before placing his order!  :p
