Author Topic: IBM Model M - lighter springs?  (Read 6174 times)
Offline misterkenny
« on: Fri, 09 May 2014, 18:08:39 »
I've recently purchased an IBM Model M (PN 1391401) and I love it. The trouble is that, after a full day of typing, my hands and wrists become fatigued. I know that Originative sells replacement springs for Cherry switches, but does anyone make lighter springs for a Model M? Or is it a standard size that I might be able to find at a hardware store? Thank you for any and all help.
Offline 1391406
Re: IBM Model M - lighter springs?
« Reply #1 on: Fri, 09 May 2014, 18:12:02 »
That's one of the main reasons I love Model F's; lighter actuation force.
« Reply #2 on: Fri, 09 May 2014, 18:59:26 »
You would realistically need to do a bolt mod, if you haven't already.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline E TwentyNine
    • Some of My Keyboards
« Reply #3 on: Fri, 09 May 2014, 19:12:10 »
Not at all.  The springs can be swapped no problem without any disassembly beyond pulling the keys and springs.
« Reply #4 on: Fri, 09 May 2014, 19:30:46 »
I have measured the actuation forces to be the same. They just "feel" lighter due to a number of factors.
Offline aref
« Reply #5 on: Fri, 09 May 2014, 19:41:43 »
Unicomp's replacement springs felt lighter to me than IBM-manufactured Model M springs. I also found Lexmark-manufactured
Model Ms to have a lighter feel than the earlier IBM-manufactured Model M keyboards. However, I never took the time to measure
actuation force on any of the above. Rather than scientific, my observations were subjective.
« Last Edit: Fri, 09 May 2014, 19:49:29 by aref »
Offline 1391406
« Reply #6 on: Fri, 09 May 2014, 20:59:53 »
I'm seeing about a 10g difference, myself. I just measured an average of 60g for my F-122 vs. 70g for my Model M. Your mileage may vary, though.
« Reply #7 on: Fri, 09 May 2014, 21:23:54 »
I have never done the chopstick of death, even once. I assumed that doing it 100+ times would be a major hassle. And how certain can you be that they are all seated properly and uniformly?
« Reply #8 on: Sat, 10 May 2014, 09:02:23 »
They seat easily, it's like putting a small metal cylinder on a plastic post.   First time doing it may take longer but you can get the hang of it quickly.
