Author Topic: great looking IBM Displaywriter  (Read 3372 times)
« on: Sat, 10 May 2014, 19:12:05 »
http://www.ebay.com/itm/321402859951
Currently $.99 and $30 shipping (for me)
This appears to be in really really good shape, though it is missing the system information card.
xwhatsit has a prototype controller for the DW that will be tested and finalized soon.
Fair warning, I have a $10 bid on this. You will have to bid $10.50 or more to win.
edit: nevermind!
Outbid notice: Bid again on IBM Displaywriter Keyboard
« Last Edit: Sat, 10 May 2014, 21:35:25 by dorkvader »
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: great looking IBM Displaywriter
« Reply #1 on: Tue, 20 May 2014, 16:16:16 »
woah, over $100! I'm guessing it will still go for less than $200 shipped.
« Reply #2 on: Tue, 20 May 2014, 16:18:27 »
Wow, dat last minute snipe for $200.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Tue, 20 May 2014, 16:18:43 »
So this board was a hall effect board?
« Reply #4 on: Tue, 20 May 2014, 16:19:15 »
Beamspring
Offline Techno Trousers
  • ʘ_ಠ
« Reply #5 on: Tue, 20 May 2014, 16:27:24 »
That definitely went for a lot more than I was expecting. With that layout, I can't see being able to use it as a daily driver on a PC, even with a compatible controller. Maybe someone just really wanted it as a collector's item?
Offline E TwentyNine
    • Some of My Keyboards
« Reply #6 on: Tue, 20 May 2014, 16:38:02 »
I'm not really seeing a problem using that as a DD.
Repurpose some keys for layering and you'd be fine.
« Reply #7 on: Tue, 20 May 2014, 18:00:17 »
Agreed. Some people consider the DW to have the most usable layout of all the beams.
Offline YakMN
« Reply #8 on: Tue, 20 May 2014, 19:27:09 »
I've been looking for one for at least 10 years. Maybe more like 20 years, since I read Zinsser's Writing with a Word Processor. Only became practical recently of course...
Offline False_Dmitry_II
« Reply #9 on: Wed, 21 May 2014, 03:16:34 »
I bet whoever was tossing it would be pissed it went for that much.
Offline YakMN
« Reply #10 on: Sat, 24 May 2014, 13:42:09 »
well, if it makes you guys feel any better, the spacebar was smashed in shipping. The right bottom part is snapped off, and it's riding up on the ENTER key, and completely jammed.
$200, and $1 worth of bubble wrap and a recycled cardboard box.
« Reply #11 on: Sat, 24 May 2014, 17:58:07 »
make sure you make it known in the feedback.
Its really unfortunate that this happened. I overpaid for shipping on my most recent beamspring, and received it in a used / recycled box and bubblewrap, but at least he used enough wrap that it arrived in the same condition he sent it in.
Offline jwaz
  • * based mod
« Reply #13 on: Sun, 25 May 2014, 21:06:59 »
I don't think anyone here feels better about a beam spring taking damage...
The damage sucks and I hope you can get compensation in some form from the seller, but as long as the metal stems aren't too badly damaged, I have to wonder if a cherry/topre spacebar couldn't be modified to fit on the mounts.
« Reply #14 on: Tue, 27 May 2014, 10:00:50 »
You probably could, but the length might be an issue. I wonder if a different bar mount switch spacebar would fit better.
Round 2:
http://www.ebay.com/itm/IBM-Displaywriter-Keyboard-/321414709535?&_trksid=p2056016.m2518.l4276
Note that this is the 92 character version which is (as far as I can tell) much less common.
« Last Edit: Tue, 27 May 2014, 10:02:56 by dorkvader »
