Author Topic: Question regarding switch modding on WASDv2  (Read 1151 times)
Offline jester_
« on: Sun, 11 May 2014, 01:41:16 »
Hey friends, I am not experienced with stem/spring swapping, but I know enough to realize the difference between PCB and plate-mount in terms of simplicity. I just got my custom WASDv2 this month and saw some conflicting information here on GH about whether it uses an "easy access plate" or not. When I took off a couple keycaps to try and look for myself it seems like there's a small area underneath the switch and most of the switch is exposed.
Is it possible to swap stems/springs on this board without soldering? Already shipped my plate mounted Filco off for a modding/lubing service and don't want to do the same with this board!
Offline daerid
    • Rossipedia
Re: Question regarding switch modding on WASDv2
« Reply #1 on: Sun, 11 May 2014, 01:56:19 »
Unfortunately, I do not believe the V2 has a mod friendly plate. I can tell you for certain on Monday.
« Reply #2 on: Sun, 11 May 2014, 02:19:10 »
looking at the picture on their website, I believe it has a standard plate.
http://www.wasdkeyboards.com/index.php/products/mechanical-keyboard/wasd-v2-104-key-barebones-mechanical-keyboard.html#ad-image-0
I am pretty sure they wanted to include this feature but were ultimately unable.
