Author Topic: Microcontroller for 5 key keyboard  (Read 2323 times)
Offline adventurepoop
  • I make keyboards, I guess.
« on: Wed, 14 May 2014, 13:52:45 »
I'm working on a 5 key keyboard, and need to figure out if i need a microcontroller and if so what would work well. I need 5 io for the keys, will I need any to get it to work with usb? What would be cheapest?
Re: Microcontroller for 5 key keyboard
« Reply #1 on: Wed, 14 May 2014, 14:01:28 »
You could use the same one that the Techkeys card uses. ATmega16u2.  It's real cheap and it can use some common firmwares
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #2 on: Wed, 14 May 2014, 14:01:56 »
Teensy is probably the easiest solution for getting started.
« Reply #3 on: Wed, 14 May 2014, 14:08:41 »
For the first one that I'm working on now I'm using an adafruit trinket, I'm looking for something in the event that I make more
« Reply #4 on: Wed, 14 May 2014, 14:13:29 »
As for the ATmega, there are four of them? One is like half the price of the other, what is the differences?
Offline hasu
  • @tmk
« Reply #5 on: Wed, 14 May 2014, 14:52:49 »
If you are looking for the cheapest chip Atmel AVR will not be answer.
I'm sure PIC18F14K50 is cheaper than those AVR, but I don't know what the cheapest is. I also want to know.
« Reply #6 on: Wed, 14 May 2014, 15:08:00 »
I think Boiler is right.  If you are beginner level with the AVR product line, then you probably want the Teensy.
Offline komar007
    • komar's blog
« Reply #7 on: Wed, 14 May 2014, 16:20:01 »
You can check out the VUSB project (http://www.obdev.at/products/vusb/index.html)
With some luck you can try to run USB even on chips like attiny2313. It won't do USB full speed, but for the purposes of a 5-key keyboard it might be enough.
