Author Topic: G710+ with custom keycaps?  (Read 6741 times)
Offline maxtortheone
« on: Sat, 17 May 2014, 08:20:10 »
Anyone here have one/have pics of one? Signed up for the Tai Hao group guy for a Dolch set and curious how the keyboard would look with non-stock caps.
Keyboards: IBM Model M 122 Key Terminal Board;  Logitech G710+; Focus FK-2001 w/ Complicated ALPS
Re: G710+ with custom keycaps?
« Reply #1 on: Sat, 17 May 2014, 08:23:36 »
« Reply #2 on: Mon, 19 May 2014, 05:03:19 »
Awesome! Now does anyone know what sizes the macro keys are?
Offline tbc
« Reply #3 on: Mon, 19 May 2014, 05:58:30 »
they're just 1x1.  same size as a regular letter.
« Reply #4 on: Mon, 19 May 2014, 06:11:05 »
No, I meant like R1 R2 etc.
Offline Oobly
« Reply #5 on: Mon, 19 May 2014, 08:23:15 »
From what I can tell it looks like from the bottom up: R1, R1, R2, R3, R4, R4 all OEM profile. It matches the "closest" row of the normal keyboard area. R1 is like the arrow keys and Z through /, R2 is like A through ', R3 is like Q through ] and R4 is like Esc through = and the F1 -> F12 keys.
With DSA profile sets it doesn't matter, the keys are all the same profile.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #6 on: Wed, 21 May 2014, 06:01:39 »
Thanks! These would fit the macro keys in your opinion?
Offline blackbox
« Reply #7 on: Thu, 22 May 2014, 01:29:46 »
Yes the DCS 1x R1 will fit
The LAN table!
